997 GT2/GT3 Forum 2005-2012
Anything to worry about this DME?
Old 02-02-2017, 11:33 PM
neurotic
neurotic's Avatar
Default Anything to worry about this DME?
Not sure what the ignition counter misfire of ~2800 means?
This is a .2 GT3 RS.
Thanks all!
Old 02-03-2017, 12:51 AM
needmoregarage
needmoregarage's Avatar
Received 1,309 Likes on 561 Posts
Not sure what that^ means but with 38 over revs only in range one it appears to be a very clean DME. Those over revs happened 54 engine hours ago but even if recent, range one is not a concern (from what I've learned).
I didn't see an explanation of ignition counter misfire here, but there's good info about over-revs.
http://www.911virgin.com/porsche/rev-range-information/
I'd probably call Duane and ask for an education.
Good luck
Old 02-03-2017, 11:16 AM
neurotic
neurotic's Avatar
That's a good idea!
Old 02-03-2017, 12:53 PM
Spyerx
Spyerx's Avatar
Received 1,729 Likes on 1,057 Posts
dme is fine
you'll get an CEL if the misfires are a concern.
you can clear the memory and track them with a durametric under acceleration etc. could have just been bad gas, hot day, etc. Or could be a coil or plug nearing end. Or could have been nothing.
Old 02-03-2017, 01:43 PM
neurotic
neurotic's Avatar
Originally Posted by Spyerx
dme is fine
thanks for the feedback; worries me a bit since car is not CPO.
Old 02-03-2017, 11:46 PM
abcut973
abcut973's Avatar
I wouldn't sweat the misfires. As mentioned any issues will trigger fault codes. Check for stored ones. Also common failures are easily fixable. I would just monitor it.
Other than that clean dme.
Old 02-04-2017, 01:37 AM
thxbuff2001
thxbuff2001's Avatar
go for it.
Old 02-04-2017, 10:27 AM
neurotic
neurotic's Avatar
Thanks guys!
Old 02-08-2017, 01:36 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,480 Likes on 2,269 Posts
virgin.
short of range 5, stop worrying. '
it's like you fell once and think you will die from concussion....
Old 02-08-2017, 05:08 AM
MJSpeed
The Rebel
MJSpeed's Avatar
Joking right? This engine has yet to be used. As for misfires, what code if any was it giving?
Old 02-08-2017, 01:08 PM
amerifrikaner
amerifrikaner's Avatar
No problemo...write the check!
Old 02-08-2017, 06:24 PM
modoz61
modoz61's Avatar
Would consider replacing ignition coils or at least be aware they are most likely source of misfires
with no engine codes yet they are still serviceable
My $0.02 worth
Quick Reply: Anything to worry about this DME?
