Subframe Question
Subframe Question
Does anyone know if there are any differences in the design of the rear subframe between the non-GT 997 models compared to GT2/GT3? The only difference I can confirm is the GT cars have solid subframe bushings, but are the pick up points and everything the same?
Of course the part numbers are all different, but comparing photos there doesn't appear to be any changes...
Thanks for any info
Thanks for any info
Thanks for any info
Thanks for any info
I know this doesn't answer your question about pick-up points on the sub frame but AP has said the GT2/3/RS 997s have the same body-in-white as the Carrera 4/Turbo. So the attach points to the tub would be the same. This is also suggested by being able to use the GT cars solid bushings on Carreras.
There are differences in the subframe cross brace. Mounting a GT3 sway bar on a Carrera necessitates a spacer on the Carrera's attach brackets because of this different sized cross brace. Or you can just swap a GT3 rear cross brace in. Here's a post about some differences in a GTS, for example, from a GT3. The only difference they could find was this rear cross brace:
http://www.brrperformance.com/blog/?p=1500
The only GT car I know that has a different subframe from its base car is the Cayman to the Cayman GT4. That has a completely different rear subframe from the 981 road going Cayman.
