997 GT2/GT3 Forum 2005-2012
GT3 Front brake pads
Old 01-30-2017, 02:42 AM
TB-GT3
TB-GT3's Avatar
Default GT3 Front brake pads
Howdy!
I'm a new member here. I currently own a .1 GT3 and the time has come to replace my front brake pads. I don't track the car, so it would be for street use and would love to reduce the squeal in the brakes whenever I roll to a stop sign. Do y'all have any recommendations?
Thanks in advance!
T.B.
Old 01-30-2017, 09:37 AM
jackb911
jackb911's Avatar
Assuming you have iron rotors, my favorite street pads are Hawk HPS. I've used them on several Porsches in the past and they have performed very well - low dust, no squealing and they are easy on the rotors.
I recently bought a set (from Pelican Parts) for my .1 GT3 but haven't installed them yet.
And BTW, welcome to the madhouse! Seriously, this forum is usually very entertaining and informative.
Old 01-30-2017, 10:31 AM
chillindrdude
chillindrdude's Avatar
+1 for HAWK, i've had good luck with them and they are priced inexpensively.
Old 01-30-2017, 10:57 AM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
For street I like the Race Technologies TS20. Extremely low dusting and even work pretty OK on track use (not great like a racing pad). I run these on my 964 for street, have on my RS too (just been a while since they were on there).
I've not used Hawks...
Old 01-30-2017, 03:37 PM
TB-GT3
TB-GT3's Avatar
Thanks for the info! I have the OEM rotors. Will the HPS work with no issues?
Old 01-30-2017, 04:04 PM
jackb911
jackb911's Avatar
I hope so, as right now I am looking at the ones I'm going to install in my .1 GT3. I will also be replacing the rotors as well with an OEM set. As I mentioned earlier, I've installed several sets of these in older Porsches including a 993 with factory Brembos, with no fitment issues.
Here are the part numbers for Hawk HPS pads for a 2007-8 997.1 GT3:
Front: HB483F.635
Rear: HB651F.624
Old 01-30-2017, 04:40 PM
TB-GT3
TB-GT3's Avatar
Front: HB483F.635
Rear: HB651F.624
Thanks so much for the help! I ordered them and am planning to install them this weekend. Let's hope for the best! I'll keep you posted
Old 03-27-2017, 10:43 AM
TB-GT3
TB-GT3's Avatar
**UPDATE** I installed the Hawk pads and have put ~200 miles on the car since then. The dust is significantly lower indeed (as jackb911 mentioned above as well) but the squealing is still there. Slightly lower but at low speeds is still present. Do you think that it might be reduced as I put more miles on them? The rotors are brand new as well. Thanks for all the help!
Old 03-27-2017, 03:42 PM
r6elmo
r6elmo's Avatar
i've used stoptech sport pads. they sell them on tire-rack - pretty cheap, low dust and low noise.
not nearly as much torque or bite as the OEM pagid pads but I can live with it.
Old 03-27-2017, 06:02 PM
nwGTS
nwGTS's Avatar
Did you follow the bedding procedure?
Old 03-27-2017, 06:15 PM
TB-GT3
TB-GT3's Avatar
No, I didn't.
Old 03-27-2017, 08:59 PM
nwGTS
nwGTS's Avatar
No, I didn't.
Start with that and report back.
Old 03-28-2017, 01:24 PM
r6elmo
r6elmo's Avatar
HPS Pads shouldn't squeal - so rebed might be needed and needed every so often, even the OEM pads will squeal.
I've run HP Plus pads on another car and those are hopeless.
Old 03-28-2017, 03:00 PM
TB-GT3
TB-GT3's Avatar
I called HPS and they told me that there might be some residue from my racing pads on the rotors and that might take some time and a couple of tries of the break-in procedure to get it off. So I will try that and see how it goes. Thanks y'all!
Old 03-29-2017, 06:18 PM
CosmosMpower
CosmosMpower's Avatar
In my experience track pad deposits wont' just go away with use. Street pads aren't abrasive enough to clean the track pad deposits off. You may have to get a rotor hone and use it with a drill to clean the surface and re-bed your street pads fresh.
Amazon Amazon
Quick Reply: GT3 Front brake pads
