997.1 GT3 Front Lip Lower Spoiler Options - Page 2 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 03-10-2017, 11:04 AM   #16
CosmosMpower
CosmosMpower's Avatar
What do you guys do if the stock lip won't come off. Just keep pulling till it breaks loose?
CosmosMpower is offline   Reply With Quote
Old 03-12-2017, 03:26 PM   #17
garyever
garyever's Avatar
If bending in the wind was the more important issue, the cup lip would have holes. Buy the cup lip.
garyever is offline   Reply With Quote
Old 03-12-2017, 05:17 PM   #18
r6elmo
r6elmo's Avatar
Quote:
it should come off easily, i start at the ends near the wheel well arch.
r6elmo is offline   Reply With Quote
Old 03-12-2017, 10:56 PM   #19
orthofrancis
User
orthofrancis's Avatar
You can squeeze in a flat head scredriver between the lip and the car and pry up gently and pull. The lip has little tabs that need to unhook.
orthofrancis is offline   Reply With Quote
Old 03-13-2017, 02:42 AM   #20
zaitsev
zaitsev's Avatar
Quote:
Originally Posted by grizfish View Post
Have you ever held your hand out into the windstream at 150 MPH?
That Porsche engineer may have been talking theory, which could be correct.
However, as an engineer who has uploaded missiles on almost every warfighter in the US inventory, I know for a fact that there is a difference between theory and real-world.
If these lips are as flexible as you claim, they will be flexing in the wind and bending in various ways depending on speed and wind deflection angle.
The holes will reduce some of the bending.
I run the cup lip on my car and it's not more flexible. If anything, it's stiffer than the standard non-cup 997.1 lip, but thinner. I destroy them every 3 months if not sooner, but the price of the cup lip is 1/4 of the standard, and you get better down force.. I feel it the most on the 405 at 5pm ;-)
zaitsev is offline   Reply With Quote
Old 03-13-2017, 02:50 PM   #21
CosmosMpower
I was able to get the stock lip off just by yanking on it sharply. Got the cup lip mounted.
Old 03-13-2017, 10:18 PM   #22
balefire
User
balefire's Avatar
Another dumb question.
Is changing the front lip a DIY?
balefire is offline   Reply With Quote
Old 03-14-2017, 01:21 AM   #23
Spyerx
Spyerx's Avatar
I can swap a front lip in 30 seconds.
Spyerx is offline   Reply With Quote
Old 03-14-2017, 02:53 AM   #24
TRAKCAR
TRAKCAR's Avatar
Even Ivan change the lip in 30 seconds and it's about the only thing I know how to do on a car. Very easy start one end only slide it in a little go around the front doing the same and tap it in with fist around the front bumper. I never bothered with the screws.
TRAKCAR is offline   Reply With Quote
Old 03-14-2017, 11:23 AM   #25
CosmosMpower
Took me about 5 mins but i had a few stubborn spots where I had to yank pretty hard to get it off. I don't think my front lip had ever been changed since 2007.
Old 03-14-2017, 08:22 PM   #26
993PET
993PET's Avatar
I was in the process of fitting my new Cup lip this afternoon and found these air deflectors attached to the underside of my bumper behind the holes for brake cooling in the stock GT3 lip. I presume they have no function with the Cup lip installed without cooling holes?
993PET is offline   Reply With Quote
Old 03-14-2017, 09:45 PM   #27
93 FireHawk 968
93 FireHawk 968's Avatar
I have a 07 997 Cup and 11 997 street version and can confirm they're interchangeable. Cup lip is stiffer and has a slightly different finish, more sheen. Both take minutes to remove and install.
93 FireHawk 968 is offline   Reply With Quote
Old 03-16-2017, 11:06 AM   #28
TheSilverFox
TheSilverFox's Avatar
Has anyone ordered cup lip from PNA Design?
TheSilverFox is offline   Reply With Quote
Old 03-19-2017, 05:37 PM   #29
993PET
993PET's Avatar
Quote:
Any advice on using these ducts with the Cup Lip.
Thanks,
JF
Related Topics
Thread Thread Starter Forum Replies Last Post
997.1 GT3 RS Front Spoiler Lip pyth Parts Marketplace 4 02-13-2017 11:57 AM
997.1 polyurethane front lip Super Sale for 2005-2008 Carreras GT3 Tek 997 Forum 12 02-08-2016 10:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
