997 GT2/GT3 Forum 2005-2012
Oil Change cost
Old 11-18-2016, 07:16 PM
F1CrazyDriver
F1CrazyDriver's Avatar
Originally Posted by ngng
if you plan on doing this yourself it's a good time to swap the plug with something that accepts a normal socket. i have a pn somewhere.
Please do. IIRC, the oem part is a female torx - PITA.
Originally Posted by Spyerx
i have motul 300v power 5w-40 in the car now. Just trying it out well, to try something different. We will run an oil test to see how it holds out relative to the Torco under similar usage.
Straight up race oil! Not recommended for street driving-correct ?
Old 11-18-2016, 07:44 PM
JB911
JB911's Avatar
I posted a thread on Napa's sale on Mobil 5W-50, $5.79 a quart
The only cheaper route is Mobil 0W-40 from Valmart $33 total
Filter from Advanced Auto around $8
Can't get cheaper than that. Return used oil to auto parts store
Old 11-18-2016, 10:38 PM
nwGTS
nwGTS's Avatar
In dealers defense (blasphemy!) you're paying for lift time. Not wrenching time. Any car on a lift means another car can't be on a lift. Opportunity cost and all that. So 15 min wrenching makes no diff when car takes an hour on the lift.
Same biz plan as dentists' chair time. Anyway, moving on....
Old 11-19-2016, 01:42 AM
CosmosMpower
CosmosMpower's Avatar
Originally Posted by F1CrazyDriver
Pending on oil brand. Buy 9 quarts. X$
oil filter ~$15
misc crush washers ~ $5
30-45 minutes time consumption
sounds like you paid ~$380 in labor
This...Mobil 1 5 quart jugs at Walmart are usually 23-25 on sale so oil is 50 bucks, filter is 15 bucks, washers 5 bucks. Should be able to DIY for 70 easily. Even if you paid an indy shop $150 for an hour of labor it's still nowhere near 400 or 460.
Old 11-19-2016, 02:09 AM
Jlopez55
Jlopez55's Avatar
Anyone have a link to a good DIY?
Old 11-19-2016, 08:34 AM
Rick GT3
Rick GT3's Avatar
https://rennlist.com/forums/997-gt2-...with-pics.html
is very easy to replace oil/filter in the GT3.
Old 11-19-2016, 09:21 AM
AudiOn19s
AudiOn19s's Avatar
300v has a detergent package in it and can be used as a street oil but not for extended change intervals like other oils...3k intervals was a general recommendation if I remember correctly.
I don't think it's a great fit as a street oil for most people but it's a fantastic track / street oil.
Old 11-19-2016, 05:07 PM
JB911
JB911's Avatar
I change the oil without lifting the car, plastic kitty litter box is low and takes all 9.5 quarts
Male or Mann filter at Advance auto is less than $10
But, since I now have an Audi S3 DD, that oil filter can't easily be found, so I order all filters online, which are of course 3 times cheaper than the dealer-
I've personally stuck with 5W-50 for the GT3, Audi doesn't have it listed as approved so I get the 0W-40 from Walmart- the 5qt jug is about $22 and the S3 only needs 6qts
GT3 can take the 0W-40, listed as factory used on Cup cars-
But I prefer the 5W-50 for Fl weather
Old 11-19-2016, 05:17 PM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
Shop has been using Motul 75-140 gear oil as a Delvac alternative and I really like it in my transmission. Shifts fantastic hot and cold is better than Delvac.
So just tried the 300v as something to try.
On the 300v, well, over 400 miles on track last week and car runs good.
No weird noises on cold startup.
HOT oil pressure seems a bit higher on the gauge at idle than Torco SR5R like 1.5bar vs. 1.0 bar.
Checked data logging of oil temps/pressures on track and they are the same (with similar ambient temps)
We'll pull a sample and compare the viscosity and wear metals. I change oil every 4-5 track days. Excessive? Maybe.
Thing i'm looking for is shearing after this kind of use.
I wouldn't run this as a street oil due to the comments above.
Old 11-19-2016, 06:36 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,735 Likes on 1,637 Posts
Motul is the only oil I use
Old 11-19-2016, 07:36 PM
Jlopez55
Jlopez55's Avatar
Thanks! ☺
Old 11-22-2016, 10:30 AM
p0pey
p0pey's Avatar
Dealer here charges $220ish for an oil change on a 997.2 GT3
Old 11-24-2016, 06:33 PM
RGAmos
2nd Gear
RGAmos's Avatar
The oil change cost you indicate is somewhat high but not outrageously so. An oil change in my GT3 RS4 was about 415$ last month at a local Porsche dealer here in Houston. The cost for my 2013 Turbo is about 25$ less.
Old 11-24-2016, 06:38 PM
ngng
ngng's Avatar
400$ for an oil change is outrageous.
Old 11-25-2016, 01:36 PM
RGAmos
2nd Gear
RGAmos's Avatar
The about 400$ oil change cost for my GT3 RS4 and Turbo is what all the three Porsche dealers here in Houston charge. The cost to change the oil in my 1984 Carrera is about 200$ done at an independent shop. Porsche dealers here will not work on the air cooled cars.
If you think a 400$ oil change cost is outrageous, compare to the 650$ cost to change the engine air filters (there are two) in the GT3 RS4.
Quick Reply: Oil Change cost
