997 GT2/GT3 Forum 2005-2012
Nose lift, CPO, PCNA
Old 03-19-2017, 10:16 PM
  #121
Rick GT3
Rick GT3's Avatar
any updates?
anyone knows how to cancel the warning malfunction light from the lift system ( I have a Durametric Pro ).
Old 03-20-2017, 02:51 PM
  #122
JB911
JB911's Avatar
Not sure Durametric can do it, perhaps disconnecting/removing the unit will do it after reconnecting the battery(?)
Old 03-20-2017, 02:55 PM
  #123
Larry Cable
Larry Cable's Avatar
Received 3,437 Likes on 2,247 Posts
Originally Posted by Rick 930
any updates?
curious what fault codes are manifest?
Old 03-20-2017, 08:31 PM
  #124
Rick GT3
Rick GT3's Avatar
No faulty codes
Old 03-21-2017, 11:53 AM
  #125
bovien
bovien's Avatar
any updates?
Someone described a drive without activating lift would do it. Not a short drive though. Don't remember the exact description.
Old 03-21-2017, 01:54 PM
  #126
JB911
JB911's Avatar
Before I had my new one installed, the Lift Malfunction kept lighting up, for months. It disappears but comes back unless it's repaired. Perhaps after removing the unit/disconnecting wires it will "forget" the lift(?)
Old 03-21-2017, 10:19 PM
  #127
Rick GT3
Rick GT3's Avatar
I had been searching front lift wiring diagram to find out which switch to disconnect w/o success. Anyone knows?
Old 03-23-2017, 12:33 PM
  #128
brownan
brownan's Avatar
Mine doesn't work the way it's supposed to either. Press button, nose goes up. Press button, nose doesn't go down. Have to get to 35MPH or whatever then it goes back down. Dealer told me that the cage was allegedly in the way of getting to the pump to fix. Couldn't be bothered to have a fight about it. Gotta read these 9 pages...maybe I'm missing an easy fix.
Old 03-23-2017, 12:42 PM
  #129
Larry Cable
I believe this is indicative of the failure of one of the pressure switches 1-bar (but I am not 1100% certain of this) ... did the dealer mention *what* fix he was unable to conduct because of the cage being in they way?
I hate to say it, but this is usually a temporary condition, on its way to complete failure eventually.
Old 06-06-2017, 03:25 PM
  #130
Larry Cable
thinking about this, how could that be, the unit is on the underside of the car under the transmission tunnel???
Old 09-05-2017, 10:49 AM
  #131
bovien
bovien's Avatar
I have, in another thread, proof that it is the mentioned pressure switch (the one indicated by '13' in the mounting face) that will fix the problem for the ones of us with the issue of lift working, but dropping only possible by exceeding then auto-drop-down-speed.
So, I'm looking into replacing that switch.
Progress status is, that I have tried to find out which compressor I have (000 111-> or 000 112 ->) as the pressure switch is dependent of the compressor version. I would like to avoid taking the entire system down, as the cooling pipes are in the way and I'm not feeling too confident on pushing them too much.
Anyone have insight in this?
Anyone have insight into the compressor type? I can see that it is marked with 04/2010, which seems right as a date, but I see no Porsche part no. Only a number from Ventrex who produced the compressor. I've tried them, they are of no help.
I'm in the US in a months time and will try to get both pressure switches home with me, as they are way more expensive in Denmark and then just replace with one and else try the other, unless anyone can enlighten me on either the date the compressor changed part no, or on a safe and easy way of taking the entire system down to check further for part no.
Only issue here is, that I from pictures of the system cannot see anywhere a Porsche part number should be placed in the compressor...
The other thread is here:
https://rennlist.com/forums/showthre...=932329&page=2
Old 09-06-2017, 03:12 PM
  #132
JB911
JB911's Avatar
My entire system was replaced and when I spoke to the tech he said he would get it in without removing coolant pipes-I assume he did.
I was not able to see the old unit, it was "sent away" probably back to Germany.
ive been using the lift sparingly during the summer due to humidity-can't wait for our so called winter when at least the humidity drops significantly 😃
Right now getting ready for hurricane Irma, warehouse 👍
Old 09-06-2017, 09:16 PM
  #133
hardrs
hardrs's Avatar
My 2010 GT3 is serviced by a Factory-owned dealership in Sydney and, when the axle lift system failed, in very much the same way as JB911's did, the dealership made me replace the entire unit. As a concession, they shared the cost of the part (A$22000.00).
From following similar threads in our forum over the past few years, it's my impression that failure of the axle lift system is a common problem - I suspect that most, if not all of the early units will fail over time.
As with the RMS leak-issue in the 996, I don't think that Porsche wants owners to know that this is a common problem, which is disingenuous on their part. Rather than doing a Factory recall, they're letting owners foot the bill for a defective part.
I'm relieved that my 2010 GT3 RS was supplied without the axle lift option!
Old 09-07-2017, 03:11 PM
  #134
point2point
point2point's Avatar
My car is currently at the dealer for CPO repair. Symptoms are similar to what's been reported in this thread - 1) pressing the button raises the nose, but dash light never comes on; 2) nose won't lower with button press, but only when speed threshold is exceeded. Porsche authorized replacement of the entire system including the front struts.
For those of you who have had the entire system replaced, have problems with the front axle lift ever returned? Is this a permanent fix or is there a design flaw that limits the life of the system?
Old 09-07-2017, 03:13 PM
  #135
Larry Cable
I'm convinced this is a symptom of the 13bar pressure switch failing...
Quick Reply: Nose lift, CPO, PCNA
