GT2 drive axle measurements
Hello,
I have a GT2 transmission and will fit it to my 964 (narrowbody), I need reinforced drive axles and need to check measurements to compare if I need custom axles or just need to switch over some parts.
Code:
Outer teething wheel side 28 Length 618 mm Numb.of teeth,ABS ring 45 Seal diam. 55 mm Wheel Side Joint Ø 102 mm Transmission Side Joint Ø 108 mm Thread Size M22x1.5 Bore Ø 10,2 mm Number of bores 6 Bolt Hole Circle Ø 94 mm
