Front right park light turning itself on - help please
Hi. I was in the garage a couple of nights ago, had the GT3 tucked up under its car cover when I noticed a glow from under it.odd.
I turns out the front right park light (997.1...so it is just a normal Little old torch size bulb) had turned on. The weird thing is the cars not on, the lights are fully off, not in home mode, and the car is shut down and alarmed.
Then it turns off. And 3 mins later on and off. Etc.
Any ideas? I pulled the front right light and checked the connections....but it's the same....it's has its own mind?
is your turn signal up or down? if you knock it left or right when exiting car it will turn on parking light mode.
