Anyone want to sell brake spring tool?
I was told to ask here if anyone has a spring tool for sale or that I could borrow.
Need to do some work on my PCCB's and can't compress the retention spring.
Here is a picture of said tool (not made anymore)
I just changed my pads over weekend on my PCCB ... I pushed in with my THUMB on the spring and seemed to have no problem... What exactly does this tool do that makes it a requirement? Not sure what I am missing or perhaps I botched my brake job up.... LOL..
That is what I use to do when I had big reds. This is the first time with a car that has PCCB. Mother Fer is stiff. I can't seem to get it to flex to remove the pin.
Unfortunately the guy that made these tools does not make them anymore.
I have one of those tools, and it is indeed a great help. However, you can do the job without it. After you remove the bolt at the back of the caliper, insert a long punch from the back, and tap it out with a hammer. Pressing down on the spring while you tap makes it a little easier.
It is a bit harder to get it back in. I always steel wool the retaining bolt before I reinsert it, because the corrosion makes it grow a little.
^^^... that is exactly what I did and worked like a charm. I was amazed that a full front pad change out only took me about 25 min on both sides. I spent more time lifting the car and getting the wheels off.. That tool does look pretty cool though.. Next tool on my list is the piston spreader.. I was able to use my hand strength and push the pistons back in but that nice red spreader I have seen mentioned elsewhere would have made it a breeze..
It helps a lot to turn the steering wheel so you have as much access as possible. Also unscrew the bolt from the retaining pin as far as possible without taking it out. Push on it to get the pin started going through as you're pressing down on the spring. When it bottoms out unscrew it and the opposite end of the pin should be far enough through that you can grab it pretty easy.
Here's my trick. Remove the retaining bolt and insert a pin - size doesn't matter as long as it fits. Then push the pin with one hand while tapping on the face of the spring with a hammer. The bolt will move across the face of the spring with little effort each time you tap the spring.
A guy was trying to sell me the tool you are looking for when I showed him my trick. He was depressed.
I can add a thought to Terry's above. If you are considering using some sort of "pin", go to your local Lowes or Home Depot and pick up some brass or aluminum rod. Comes in several diameters, lots of us shooters carry a short piece to the range for the occasional squib load, where a reload or factory bullet has little or no powder, just a primer, and it pushes the bullet part way into the barrel. A bad scenario if you don't notice, and follow up with another round.
I carry a rod in about 9mm and another in about .45 size, aluminum, and rarely nowadays have to tap out a bullet. So you can pick up a length of rod, cut a short length off, maybe file or grind a point on one end, and tap out the caliper pin and being aluminum, or brass, not likely damage anything. With a point it will probably self-guide into the opposite side. As for pressing the spring down, for that I have no suggestion.
I keep some of the rods around for this and that.
all the best....
all the best....
