997 GT2/GT3 Forum 2005-2012
Water Wetter
Old 05-11-2015, 12:45 AM
hillsdonsmith
hillsdonsmith's Avatar
Default Water Wetter
I have a .2 RS that I will use for a DE at the end of this month. 2010 model, 50,000 km. Car has CPO for another 1.5 yrs. Dealership will pin coolant lines but will void CPO if a non factory trained mechanic pins them.
Before I get flamed, this will be my only DE this year. I have decided to not pin coolant lines until engine needs to come out for something else - clutch, LSD etc. However, I have decided to dump coolant for this DE and fill w water. This may not help me if I dump it on my rear wheels under load but should prevent carnage behind me.
Water would be in car x 1 month.
1. Is distilled better than tap water?
2. Do I need lubricant, as found in water wetter products for this short period or not?
3. If so, what product is recommended? (Seems to be some controversy from what I have read).
Thank you.
Cheers
Mark
Old 05-11-2015, 02:01 AM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
Had WW in my car for over a year. About 6mo ago had water pump replaced preventatively. Everything was spotless.
Anyway. Use distilled water only. DO NOT USE TAP WATER. it's one or 2 bottles of WW needed. Forget.
And yes this is a good idea for track use. You can put coolant back in.
Old 05-11-2015, 11:34 AM
hillsdonsmith
Thanks for the tips.
So, is it important to put water wetter in or can I run distilled water only for a month (not sure if I can find water wetter quickly enough).
Thx
Mark
Old 05-11-2015, 05:25 PM
entityx
entityx's Avatar
Run it with WW, it helps keep the water pump properly lubricated
Red Line 80204 Water Wetter - 12 oz.: Amazon.ca: Automotive Red Line 80204 Water Wetter - 12 oz.: Amazon.ca: Automotive
Old 05-11-2015, 05:31 PM
CosmosMpower
CosmosMpower's Avatar
I think WW helps prevent corrosion too but if it's just for a month I wouldn't be too worried either way.
Quick Reply: Water Wetter
