Coolant bleeder
And if that it the bleed and If the silver tab indicates the bleeder is open - well it's been open since I've had car serviced so that is likely the culprit of my problem
you pull the metal bracket thing on top so it's standing on end to bleed it (plastic part in middle extends, flat part of paper clip thing ends on top, little round paper clip feet on bottom)
The way in the pics is closed
Also pressure is still building in reservoir with bleeder open (tab facing up)
Ie when I open cap after having bleeder open pressure still comes out
