997 GT2/GT3 Forum 2005-2012
Shaping up a new-to-me 07 GT3
Old 06-04-2014, 10:34 PM
Tom@TPC Racing
Tom@TPC Racing's Avatar
Default Shaping up a new-to-me 07 GT3(that turned into a build thread)
I bought this 07 GT3 from a Chevy dealer in Albany, NY back in March. This car was pretty rough around the edges(its all can afford on a grease monkey's salary ). The dealer left the key ON in the ignition and drained the battery dead in the showroom. The previous owner spent good money on mods but just didn't turned out too well. The good news is the handling was so bad, even at legal highway speed, I doubt that any one would track this car for more than a few laps. Here's the journey to shaping her up!
Last edited by Tom@TPC Racing; 08-08-2018 at 09:59 AM. Reason: Revised the title of this thread appropriately. 08-08-2018
The following 2 users liked this post by Tom@TPC Racing:
paddlefoot64 (06-06-2020), Robocop305 (07-24-2022)
Old 06-04-2014, 10:39 PM
Tom@TPC Racing
The very next day after driving the car home I had to put it on the dyno because it felt pretty flat. It does have an aftermarket cone air filter, which is not my preference. Sure enough power is a little down. And looks like its never had spark plugs and fuel filter change so let's do it!
Robocop305 (11-08-2023)
Old 06-04-2014, 10:45 PM
Tom@TPC Racing
I really wish this car came with the factory airbox because it cost about $800!! Need to figure something out with the airbox... and it needs a MAF sensor because it was coated with the cone filter oil.
Old 06-04-2014, 10:49 PM
GTEE3
GTEE3's Avatar
Tom,
nice find, how many miles?
Old 06-04-2014, 10:52 PM
Tom@TPC Racing
Default The Airbox Saga
If I am to spend 800 bucks on an airbox, it ain't going to be the stock one! The pictures are worth a thousand words.
Old 06-04-2014, 10:56 PM
Tom@TPC Racing
Default The Airbox Saga, Part 2
All that work was worth it. Check out the dyno! All dyno runs made will lid closed.
Old 06-04-2014, 11:07 PM
Jamie_GT3
Jamie_GT3's Avatar
Cup Box is a nice cheap solution compared to the stock box... Did you do the plugs and the box at the same time and re dyno?
Old 06-04-2014, 11:19 PM
Tom@TPC Racing
Default On to the suspension
As I said before, the previous owner spend good money on mods but the results were less than ideal. Just look at this set up... Not one corner was right. I was actually amazing that the steering wheel was even remotely straight! Got some sorting out to do. I only work on my car after shop hours and weekends in case you were wondering.
Old 06-04-2014, 11:21 PM
Jamie_GT3
Jamie_GT3's Avatar
That's a hell of a bend...
Old 06-04-2014, 11:35 PM
993Brendan
993Brendan's Avatar
Nice write up! Congrats on the car.
Old 06-04-2014, 11:37 PM
Tom@TPC Racing
As I swap out the suspension parts, I Cleaned, I Cleaned, and I Cleaned. It take not time to change parts but it take hours and hours to clean. I used up 2 cases of gum cutter and a gallon of simple green.
T-Rex06
T-Rex06's Avatar
It's good to see that you're putting in much needed TLC to bring the car back to how it's supposed to be. Congrats on the purchase.
Terrance
Old 06-04-2014, 11:47 PM
Mvez
Mvez's Avatar
Congrats on the new ride.
You've inspired me to clean my crankcase....
Old 06-05-2014, 12:03 AM
Tom@TPC Racing
Default More suspension
There's more than one way to setup a car. It is my preference to setup the front geometry so that I don't have to run a stiffer rear sway bar for push, which this car had. Not only did I got rid for the GT2 rear bar for the stock .1GT3 rear bar, I also added a stiffer front bar for more rear grip. I don't have money to change shocks & springs now so the best I can do is put on .2 front springs that are laying around.
I want to take the opportunity to give Michael Levitas, owner of TPC Racing a big shout out. Thank You Very Much, Mike, for letting me use the shop after hours and for taking me along to the races to sponge up the setup knowledge from the pro drivers.
koja997 (10-03-2019), paddlefoot64 (06-06-2020)
Old 06-05-2014, 12:10 AM
Tom@TPC Racing
Default The finishing touches...
...for now.
The previous owner bought genuine Porsche RS rear wheels. Which looks neat...BUT NOT TRACKABLE ON A NARROW BODY!!! Had to buy a new set of wheel.
Bump tested and corner balanced. Finally, ready for the track.
cbracerx (05-26-2021)
Quick Reply: Shaping up a new-to-me 07 GT3
