Shaping up a new-to-me 07 GT3
#586
Oh c'mon i was hoping you'd have put cup uprights on there, subframes, etc etc :-)
Will be interesting to gauge your perspective. I do feel the 997 even the 380mm fronts (my car was PCCB car so has proper spacing on upright, but I have red calipers to confuse people lol) like I have is front bias heavy, and I use a different rotor in the rear (Brembo type 3) , with slightly more bite to help. And it did. Fronts I use type5. Very happy with this setup.
It's nice to have some drivers in this forum still!!!!!
lostdog (02-11-2020)
#587
Okay, no quite a bolt-on
Got a few hours to spare on Sunday afternoon before having to plan and pack to display at the 2016 PRI(Performance Racing Industry) Show at Indianapolis so let's do this.
After removing the old parts immediately there's a slight problem, the adapter doesn't seat flush on the GT3 upright(aka wheel carrier) like it does on a Turbo upright. Well this was unexpected!
The GT3 upright is a "boxed" design, the Turbo and Carrera uprights aren't. The step at the end of the adapter interferes with the boxed design.
I drove the car in to do this and have to on drive before dinner time so no point in staring at the problem as daylight is burning. Accept the problem and machine the adapters.
Another slight problem- The upper square pad and other areas on the upright is 0.007 inch taller than the caliper contact pad. 0.007 inch is not much, I could've torque down the adapter and would likely hold in place since the interference is barely over the allowable tolerance of some aluminum engine cylinder heads but my OCD'ness won't allow this. Solution- Pneumatic sander to the black marked areas.
For reference, the original 350mm caliper mounting doesn't overlap these areas.
After pneumatic sanding and checking with machinist straight edge.
Adapter fitted and tested the centering of rotor to caliper.
Smooth sailing from here. Which was what I thought 5 hours ago. LOL
I'd never have used the word sexy to describe brakes but now I have second thoughts on that. I am very happy with the fit. Time to go home for dinner and pack for PRI.
Here's side by side before/after machining.
PS- Anyone going to PRI look us up at booth #2610.
#588
Nice Job. #useyourtools !!!!
#589
Driver for life.
#590
Nicely done upgrade. I was considering the same idea 2 weeks ago for my 997.1 GT3 that also gets used as the Porsche gods intended, but ran out of time and went with 350mm oem again and new calliper. Love this setup, even at the lowly 350mm!
Time for new callipers
New callipers and Essex AP racing discs look awesome
#591
Nice upgrade, Tom.
Sooooooooo what are you doing with your old calipers and rotors???
#592
#593
Thank you, Sir!
#595
Guess what I'm making at 1am on a Monday night
It has been getting more and more challenging to find time to work on my own car with the success of our many products including DSC and Tractive. Working 10+ hours a day, 6 sometimes 7 days. Here a project I've been wanting to do this since last Fall, finally pulled myself together to get some of it done. Feeling a little cranky 'cause I'm tired and haven't had dinner but must take advantage of this momentum. First person to guess right on what I'm making gets bragging rights.
[IMG]https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/80-
img_7822_c2f08a5ad7e92f0201d256d36b3a988dd97c26b3.jpg[/IMG]
#600
