GT3 clutch
GT3 clutch
How can I tell when my clutch needs to be replaced ?
I own a 997 MK2 and my pedal moves a tad heavier/harder than my friend's MK1 clutch pedal. Is this normal, or is my clutch soon due for replacement ?
Thanks for your input. The clutch is not slipping. It behaves quite normally. I just find the fact wierd, that my clutch is harder to press than the clutch in the MK1.
my peddle got stiff and occasional slip. it also started to jitter very badly on reverse. also noticed a squeaking noise when depressing peddle. its in the garage now getting a new GT3 RS 4.0 clutch kit.. it has 30k km on it.
@Guest89: Yes.
You can usually tell if your clutch needs to be replaced if it is slipping as others indicated or if the pedal gets unusually stiffer with a much lower engagement point.
