997 GT3 GEN 1 TIRE QUESTIONS
I am needing to replace my Michelin Pilot Sport Cups.
Has anyone tried to go up 1 size in tires. Fronts are now 235/35/19. Does anyone know if the 245/35/19 will fit with the original rims and do they rub?
The original rears are 305/30/19 and 325/30/19 are available. Will these rub ont a GT3?
Thanks everyone for the help
Searched on "245 front" in the 997 GT2/GT3 forum
https://rennlist.com/forums/showthre...ferrerid=68981
the issue is ride height with a 2007 and a 245
a 245/35/19 is slightly taller so on bigger bumps, if the car is lower, you can get the tire hitting the fender liner
at stock ride height you will be fine
to keep the factory rake you will have to drop the front about 5mm
another alternative, if you want to run PSS tires, there is a 255/30/19 that will also fit
