997.2 GT3 / Nose Lift vs Handling
Greetings from Istanbul everyone!
Thanks to you guys, I'm having a blast with my 3. So far I have done 3 trackdays and I'm in love with the Mezger power !
Unfortunately, I'm constantly scraping and hitting the front end and finally decided to buy a nose lift system..
The Techart system looks great, but I'm not sure about changing the springs...
Techart does not give any info regarding the spring rates which really bothers me.... I don't want to destroy the handling characteristics of the car.
It would be great if you guys could share you experiences with this system.
Where is the video of Walter Rohrl tracking a GT3 on the ring with and without the nose lift system? Two different cars, same exact time, one with lift the other without.
That would be the same time with the Porsche lift solution. Cannot vouch for aftermarket systems. Though I imagine the outcome would be just as equal. Though far mote expensive than the lift from the factory.
Last time I checked the aftermarket system was nearly ten grand American.
Well the KW variant is not compatible with PASM, and provides less lift compared to the Techart
Cargaphic is a very nice system reducing the unsprung mass ! However sharing the airbag compressor is a very scary idea! Due to road conditions in Istanbul, I might have to use the system more than 10 times a day....
I'm not sure if the compressor could handle the punishment 7/24 And what if the compressor fails and you crash.... WOW
Tried to contact Techart HQ in Germany, to ask for the spring rates etc.... The tech guy was out of office bad luck!
Admin
http://www.cargraphic.de/sources/vid...rlift-ENG.html
Tried to contact Techart HQ in Germany, to ask for the spring.... The tech guy was out of office
Meister, what is your opinion regarding the airbag issue...
That little compressor is literally working his *** off everytime What if the compressor fails... No Airbags?
All This coolant & centerlock issues got me trippin big time, so to be honest I'm kinda scared
Thanks alot!
Thanks alot!
Admin
I have the impression that your local Porsche dealer (or whoever told you that there is a connection between the airbags and a tire compressor) is dangerously incompetent.
Now, that is scary indeed.
Still plays with cars.
Airbags are inflated by a pyrotechnic - i.e. explosion. No compressor. The Cayenne has an air compressor to inflate air bags in the suspension - which is a far different thing and NOT applicable to your GT3.
Best,
Best,
good point on the KW with PASM and lift height. You have done your homework!
all things being considered, i would never install it nor buy a GT3 that has the option.
I would crank my coilover suspension up higher then stock and continue to take bumps/dips side on.
How expensive is it to just buy 10 front spoilers? On the mk II cars it's very easy to take off and install compared to previous generations.
Or you can just take it off for off track driving. Yeah, less pimp but you got the wrong car if you goal is bling.
Admin
This is not acceptable.
You know that people live in cities that are not flat, right?
Some of them even have driveways and garages with steep angles..
Just saying..
I'm not sure how helpful tcsracing1's advice is: "Just crank up the ride height to about that of a F-150 and you'll be fine..." I have the OEM system and I can say which my car would be almost undriveable here in Pittsburgh without it. I need it just to get into and out of my driveway and I use it while on the street usually multiple times per drive. System works great and reduces my stress level considerably. Even so, I've accumulated some unavoidable "battle scars" on the splitter....
