997 GT2/GT3 Forum 2005-2012
Catastrophic Coolant Hose Coupling Failure Registry
Old 03-29-2011, 10:55 AM
  #91
FFaust
FFaust's Avatar
My motor has been out twice in the last month for leaks, the last and current at dealership (don't ask), but the timing was such that I could not fix the problem. Dealer did the flush and accepted to fill with W + WW at my request, not even any hesitation on their part
Old 03-29-2011, 12:11 PM
  #92
NVRANUF
NVRANUF's Avatar
Francois, did they permanently fix (by the weld or bolt method) the "coolant hose failure issue" for you, covered in this thread?
Old 03-29-2011, 10:08 PM
  #93
FFaust
FFaust's Avatar
Sorry Peter, I should have been more specific, I was running out of the house when I replied.
When I said that I could not fix the problem, I meant fix permanently. So no, couplings not fixed, welded, pinned, or anything else
So I'll be running with W + wetter until next time.
Old 04-11-2011, 04:37 PM
  #94
Goldcrest_Allen
4th Gear
Goldcrest_Allen's Avatar
Here's pictures of our welded solution-
http://www.goldcrestmotorsports.com/...ing/index.html
(Sorry for the shameless self plug)
Old 04-11-2011, 04:48 PM
  #95
lp997
lp997's Avatar
Two questions:
Do we have to drop the motor to install this?
What is the cost?
Old 04-12-2011, 10:05 AM
  #96
Goldcrest_Allen
4th Gear
Originally Posted by lp997
Two questions:
What is the cost?
Yes. The engine needs to come out.
The cost is about $1,500 for the entire project.
(This does not include any hoses if they need replacement.)
Old 04-12-2011, 12:39 PM
  #97
rlightfine
rlightfine's Avatar
Can you share the cost for the entire project?
Old 04-12-2011, 01:01 PM
  #98
Goldcrest_Allen
4th Gear
Sorry, should have been more specific.
Old 04-12-2011, 01:54 PM
  #99
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
2004 996 GT3
Mont Tremblant
18,000 KMs
Dealer replaced water pump housing and hose.
Fitting blew out on the driver's side of the water pump housing.
I am making this thread sticky.
Old 04-12-2011, 02:01 PM
  #100
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
as you should RMS and maybe Ice mode.
Old 04-12-2011, 10:21 PM
  #101
lp997
lp997's Avatar
I will keep the upgrade in mind when my car is out of warranty. For now, Porsche can pay for this. Update on my car: Porsche fixed it at no cost. Got the car back and drove 120 miles and completely broke down
Update: now in month 2, still do not have my car back...plus side, saved two months of miles. Glad this isn't my DD
Old 04-13-2011, 01:05 PM
  #102
911SLOW
Admin
911SLOW's Avatar
Originally Posted by Bob Rouleau
2004 996 GT3
Mont Tremblant
18,000 KMs
Good call Bob!
(And don't worry about the sticky, we need a dozen more to match the Cayenne subforum... )
Added a diagram that might help categorizing the incidents per affected area.
Old 04-13-2011, 03:36 PM
  #103
savyboy
savyboy's Avatar
We are working a fix for .1 cars at this moment and have a project car in the shop. Here is a pic of a fitting that upon dropping the engine we saw was about to fall out. We almost crapped our pants when we saw this as we had no idea one was already falling out!
I now have several hours of track time on my retrofitted car (2010 GT3RS- the initial guinea pig) with no problems. Last image is one of my early prototypes: threaded, shouldered, ultra-strong machined aluminum tubing in combination with an an application specific (temp/ethelyne glycol resistant) thread locker/sealant. It should be bomb-proof. Refining this solution at this moment.
Old 04-13-2011, 11:05 PM
  #104
Tim Kay
Tim Kay's Avatar
That's art... As it should be
Old 04-26-2011, 04:11 PM
  #105
Yoops Racing
Yoops Racing's Avatar
Nice Work Allen....
Quick Reply: Catastrophic Coolant Hose Coupling Failure Registry
