997 GT2/GT3 Forum 2005-2012
Catastrophic Coolant Hose Coupling Failure Registry
Old 07-29-2015, 08:13 PM
  #586
Saru385
Saru385's Avatar
can't speak for how all shops do this, but SPM uses the bbi billet inserts that Spyerx mentioned. bbi made them beefier to make welding a bit easier/safer, but they also help if you go the pinning route since they give you some more material to thread.
so for my car, the stock pipes will all get pulled out and tossed (maybe i'll keep as a souvenir) and the new bbi ones are tapped into place and pinned.
this youtube video shows another method where they retain the stock pieces and go with a knurling and JB Weld approach. i haven't heard of people on here doing that for their GT3s, but sounds like this shop has done this on a number of Porsches.
Old 07-29-2015, 11:18 PM
  #587
jonwb
jonwb's Avatar
Thanks Saru... quick follow-up, what glue did they use when the pushed in the bbi fittings (prior to drill / tap / screw (pin)?
Old 07-30-2015, 01:48 AM
  #588
Saru385
Saru385's Avatar
i'm bringing my car in this weekend for the work, so not sure exactly what sort of glue/epoxy they will use. i'll ask and update once i know.
Old 07-30-2015, 01:48 PM
  #589
Spyerx
Spyerx's Avatar
Received 1,729 Likes on 1,057 Posts
I like elmers :-)
Old 07-30-2015, 03:21 PM
  #590
jonwb
jonwb's Avatar
^^^ that stuff is delicious! LOL
Old 07-30-2015, 05:15 PM
  #591
Gofishracing
Gofishracing's Avatar
Pretty scary isn't it TT Surgeon & DLG ?
Old 08-05-2015, 03:23 AM
  #592
mooty
GT3 player par excellence
mooty's Avatar
Received 5,481 Likes on 2,269 Posts
dont be foolish.
they WILL fail, it's a matter of when.
which car fails when? that's a crap shoot.
i have garage queens, i have track *****. which fails, no pattern.
when i dropped motor, some fitting are tight. some you lightly pull it, falls out
i had them all pulled
Old 08-05-2015, 03:17 PM
  #593
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Elmers also makes for a great imitation skin for 3rd graders, LOL :-)
A friend totaled a BMW while running over coolant from a car ahead that lost its coolant, geez it was a brutal accident.
Old 08-12-2015, 08:34 PM
  #594
Black2004GT3
Black2004GT3's Avatar
2004 GT3
59,600 miles
Driving on street
Fitting came completely out.
I had all the fittings welded at Vortex Motorsports.
Old 08-13-2015, 08:50 AM
  #595
Gofishracing
Another engine drop and fix on a beautiful Black GT3RS at Precision Motors this week.
Old 08-28-2015, 03:45 PM
  #596
viprklr
viprklr's Avatar
Default Coolant lines
2003
Porsche 996TT
Coolant line let loose at Indy HPDE
21,672 miles
Going to shop 8/29/15 to have the coolant lines pinned.
Outcome should be good after writing check.
Old 08-31-2015, 08:11 PM
  #597
tsky
tsky's Avatar
Mid August 2015,
2004 996TT
Mileage: 106K
My mechanic had replaced my cracked, leaking coolant expansion tank only a few days before the incident. While driving on the highway on a warm day (90+F), I got the coolant low warning and I immediately exited the freeway. I thought it must be due to the previous repairs and had the car towed back to mechanic's shop. He was puzzled as he checked all the hoses to the tank and couldn't find anything wrong. Later in the day, he sent me this picture he took using a fiber optic camera.
I'm not sure which fitting this is. He fixed it by having a machine shop knurl the fitting and glued back as seen in the video Saru posted.
It's back on the road but obviously we have to fix all the fittings before I'll be confident driving it in hot weather or long distances. We're going to make a plan to pull the motor, check the clutch, replace lots of rubber, and fix all the coolant fittings. I don't know which route to take be it pin, weld, or knurl which is why I'm researching this and how I found this thread.
Boo.
Old 09-01-2015, 04:31 PM
  #598
Gofishracing
file a complaint anyway. ya never know- one day they may say they have enough compalints to offer reimbursement.
Old 09-06-2015, 08:21 PM
  #599
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default BBi Autosport Porsche Coolant Pipe Fix
Rennlist Members,
Coolant pipe failure is an inevitable problem with the Porsche GT1-block equipped models (GT3, GT2, Turbo). Bonded together by adhesives, the factory pipes will eventually fail and be catastrophic.
As the best preventative fix/solution for this problem, BBi Autosport offers replacement billet aluminum coolant pipes to be permanently welded. Compared to the factory fittings, the replacement BBi billet fittings offers superior metallurgy to allow stronger, higher quality welds.
We offer this complete service at our facility in Southern California from start to finish. For clients that are not local, we work with many Porsche dealerships and shops throughout the US to have the parts shipped to us for the welding service.
Despite this being the best solution for the problem, the biggest caveat is being able to properly weld the fittings as it requires extensive surface preparation and skill. We developed special tools here to pressure test each set for for leaks prior to shipping.
Here are some pictures of the entire process below. Please contact us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com for all questions and inquiries!
Removing the engine
(Click on images for higher resolution)
Disassembling the top end
Removing the factory fittings that are held together with adhesive
Time to weld on replacement BBi Autosport billet fittings
Finished Product:
- Jerry@BBiAutosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Old 09-08-2015, 03:18 PM
  #600
Spyerx
Spyerx's Avatar
Jerry takes nice pics.
I had BBI to mine over a year ago, many, many track days later they're holding with no issues. On removal, a few of the pipes required little to no heat and very little force to remove. Ticking time bomb....
Quick Reply: Catastrophic Coolant Hose Coupling Failure Registry
