Catastrophic Coolant Hose Coupling Failure Registry
#31
Rennlisters, during my race at Miller Motorsport Park I had a coolant line failure that should not have occured. My 2004 GT3 has a secondary coolant line from the waterpump next to the primary coolant line. This secondary line has a press fitting into the waterpump with no fastner. It then travels up to the powersteering pump where it is connected. Both pumps have the pressed fitting with metal pipe, both pipes are joined with a rubber hose using hose clamps, I would image for vibration. It appears to have been bonded with adhesive, and after 7500 miles it failed, just popped out during a race which cost me my National Championship and possibly a engine. No warning, no drips or leaks, just pop and a spray of coolant on to the engine and right rear suspension.
Would like to hear if others have had the same problem, because trust me, I will give Porsche and ear full...
Look and weep...
Look and weep...
#32
Add me to the list:
2007
997 GT3
46,xxx miles Daily driver and DE car, but its been over a year since its been to the track
Dumped all the coolant on the way home from work driving at 30 mph
Car at dealer now, will add details when I know them.
2007
997 GT3
#33
GT3 player par excellence
non rennlister
today
infineon
997GT3
about 15-16k miles
T11 i believe.
today
infineon
997GT3
about 15-16k miles
T11 i believe.
#34
Year: 2007
Model: 997TT
Mileage: 18k
Circumstance: Palm Beach International Raceway, 3rd lap coolant line seperated fr block ect...day over. Engine pulled and repaired.
Ken
Model: 997TT
Mileage: 18k
Ken
#35
Year: 2004
Model: 996 GT3
Mileage 35,000 miles [2011]
Issue: Press fit coupling at water pump. All coolant drops in about 5 seconds!
Solution: TBD [going to shop today]
Pics below.
Model: 996 GT3
Pics below.
#36
^ add me as a victim of the above fail too!
2007 GT3RS
Turn 8 at WGI
Car had ~ 35k mils then.
Press fit coupling came unglued. Total coolant loss in less than a minute.
Repaired with OEM parts.
2007 GT3RS
Turn 8 at WGI
#37
I'm surprised there has not been a class action lawsuit undertaken. Porsche is well aware of this problem (Excellence Magazine) and has done nothing to rectify the problem. costs for repair excedd $3500.
#39
Any 2010-11's with this issue?
#40
Again, fortunately, there were no casualties behind me.
#41
If/when someone dies, even VW won't have the liability insurance to write the check to compensate the families of a couple of wealthy GT3 RS owners in pine boxes.
#42
Other than changing all the Hoses - anything else that can be done to the couplings to prevent the failure? TB weld? Sorry for the dumb question but just trying to be proactive!.
#43
Admin
Ritesh it is not a hose issue but a press fitting issue. Do a search here we have more information than Porsche would like us to.. : )
And yes welding them is a final solution.
#44
I put water wetter in my car, so we are less lekely to spin when it happens.
#45
And get your check book out, the engine has to be removed and porsche charges $3500 just to drop it! I had the fittings replaced by porsche only to have the failure occur a second time at the track. Their liability is growing!
