997 GT2/GT3 Forum 2005-2012
Catastrophic Coolant Hose Coupling Failure Registry
Old 02-20-2012, 07:15 PM
  #196
scott40
scott40's Avatar
Originally Posted by old gray wolf
2004 GT3. First time at Watkins Glen in '08. 37K. J pipe behind power steering pump. Replaced housing w/ the bad pipe under warranty. Second time at Mid Ohio in '11. Same pipe blew out. Removed all of Porsche's sealant and reinstalled pipe using J B Weld epoxy which has a 1000 psi shear strength and is good to 300F, then safety wired the hose clamp to a bolt.
Will pin all pipes prior to next event.
Is WrightMotorsports going to do the pinning?
Old 02-21-2012, 02:32 PM
  #197
scott40
scott40's Avatar
Is anyone aware of a bulletin issued by Porsche on this issue? I am told there is one...
Old 02-25-2012, 12:08 AM
  #198
HiWind
HiWind's Avatar
Question
... That would be news - where dya hear that Scott?
Old 02-25-2012, 12:21 AM
  #199
Alan C.
Alan C.'s Avatar
I was at my local dealership yesterday and was told that there was a new fix from Porsche. The tech said their local rep indicated that there would be a kit available for something like $1700 in parts. Maybe someone else can confirm this.
Old 02-25-2012, 11:12 AM
  #200
SH || NC
SH || NC's Avatar
Whomever told you this, get a copy of it, scan and post.
Old 02-25-2012, 02:58 PM
  #201
HiWind
HiWind's Avatar
Originally Posted by Alan C.
... rep said something like $1700 in parts
.... That's just funny when you consider the cost of the Sharky parts. Maybe it includes lateral sphincterotomy.
Old 02-25-2012, 03:34 PM
  #202
scott40
scott40's Avatar
Will find out more tonight. I think Alan and I use the same dealership. I didn't hear about the $1700 fix, but if Porsche has a fix, they sure as heck better be doing it gratis, especially on warrantied cars.
Old 02-25-2012, 05:30 PM
  #203
Alan C.
Alan C.'s Avatar
Nope, that is an extra cost option
Scott, I'll be at POV tonight, probably early. I was by there earlier today picking up the GTS. All of a sudden the PDK needed a Depends.
Joe told me about the Porsche repair parts. He thought welding would be best followed by pinning unless it was a warranty repair. He also thought Porsche might put the parts in under warranty if the car developed a leak under warranty.
Would be nice if PCNA steps up to the plate.
Old 02-26-2012, 12:29 AM
  #204
Alan C.
Alan C.'s Avatar
I spoke with my service writer this evening at POV. He told me he had ordered a set of the new parts for evaluation. The order was for over night delivery 4 days ago. He's still waiting.
Scott, if you get a chance check with Dave early next week. I will be down and out for a while starting Monday morning.
Old 02-26-2012, 08:47 AM
  #205
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Old 02-28-2012, 09:33 AM
  #206
deputydog95
deputydog95's Avatar
What do you get for $1700? Do they replace all the manifolds with welded fittings? Sounds pricey considering you need to put out another $800 to R&R the engine to do the work.
Old 02-28-2012, 10:55 AM
  #207
NorthVan
NorthVan's Avatar
I had my R+R and welds done for a little more then that. Lots of $ but I don't need to worry about this issue now.
Old 02-28-2012, 12:27 PM
  #208
deputydog95
That's about standard for the repair. Seems pricey to charge $1700 in parts alone and then another $800 on top to R&R the engine. Just curious as to what those parts are.
Old 03-02-2012, 01:34 PM
  #209
scott40
scott40's Avatar
Our local PCA region issued this today:
OVR COOLANT LINE SAFETY NOTICE UPDATE
It appears that Porsche has quietly addressed the issue of the coolant lines coming unglued from their housings in GT1 type engines. The housings have been re-engineered to increase the bonding surface area of the tubes and a new, high-strength/heat-resistant bonding material is used. We are hoping that they can tell us when they started using these new parts but unfortunately at this point that information is not available. It does appear that 2010 and later GT3 RS’s have them so one would assume that this would include the Turbo’s as well. *
Based on this, we will exempt these cars from the requirement that they MUST either run water with Water Wetter in their coolant systems or mechanically secure these pipes. However, unless your dealer advises against it, we strongly encourage the use of distilled water and Water Wetter. In fact, Porsche of the Village is offering a program where they will drain and capture your coolant and store it for you for future use. Then flush the system to remove the remaining glycol coolant then refill it with distilled water and Water Wetter for approximately $200.
We also want to caution owners of earlier cars that the fitting located behind the power steering pump, which has been the main problem, is not the only one that can fail. There are ones behind the alternator that have failed as well. Therefore, if you are addressing this problem by welding or pinning these fittings, you must do all of them. Even after this has been done you are still encouraged to change over to the distilled water with Water Wetter for track use since hose failures can also occur.
Please feel free to contact us if you have any questions,
Old 03-14-2012, 01:13 PM
  #210
fc-racer
fc-racer's Avatar
Was there any word on what the new parts looked like? Did your shop receive them from Germany?
Quick Reply: Catastrophic Coolant Hose Coupling Failure Registry
