failure of rear caliper bolt
#63
#64
I've ordered timeserts, so I'll be ready. Still need to get my break in miles done.
#67
Ahh, OK, right. The only time I did it, I changed the rotors, so calipers came off. Now I get it. So, there is some benefit to being in lust with this old beast, and not having coin to upgrade.
#70
You might suppose so, but other manufacturers do the same. If you get a brake upgrade from Alcon you also have to remove the calipers (even the fronts) if you want to change pads.
#71
Really?! I'm surprised. I guess maybe the design have more rigidity? Otherwise, I don't see any advantage of requiring the calipers off to change pads. (Consider how often that has to be done on a race car..)
#72
why not just change over to 996 turbo rear calipers! problem solved and will only cost your a couple hundred bucks.. use the spacer to bring out the caliper and run the 350mm rotor! vivid racing sell them for like 100 bucks. spacer and bolts or make your own spacer
#73
Bad news, kids. The problem also occurs with front calipers and infects 996s as well as 997s. You may not notice it until you change front rotors but it's happening. Diagnose it by putting a socket key on the caliper bolt and see if it moves easily. If it does, you're a member of the Timecert club.
#74
Joining the club of lost threads Lots of travel dictated having a local shop did some suspension work for me. Couple of days after I got back I was at Laguna Seca going into turn 6 when I heard a PING. Backed off and did some wiggle checks - everything felt okay so I assumed I'd hit something someone else's car had shed (number of off-and-ons at that spot). Next turn I heard another loud PING and decided it was time to head to the pits. As I worked my way around the pressure in the left front tire started to climb. ByBy the time I hit the lower exit the tire went flat so I thought I'd holed the tire, but when I backed off to make the turn into hot pit the car lurched to a stop. I limped the last 60 feet or so to the paddock, expecting a shredded tire - waiting friend pointed out my wheel wasn't turning. Once parked I could see the caliper pointing up into the wheel and the lower bolt completely free of the carrier. When everything had cooled enough for me to start disassembly I found the thread in the lower gone and the upper bolt hanging on and bent at a 30-degree angle. The caliper-to-wheel contact had compromised the wheel to the point that the flat was caused by the grooves worn into the middle of the wheel. Time for studs methinks...
#75
Joining the club of lost threads Lots of travel dictated having a local shop did some suspension work for me. Couple of days after I got back I was at Laguna Seca going into turn 6 when I heard a PING. Backed off and did some wiggle checks - everything felt okay so I assumed I'd hit something someone else's car had shed (number of off-and-ons at that spot). Next lap around hear another loud PING and decided it was time to head to the pits. As I worked my way around the pressure in the left front tire started to climb. By the time I hit the lower exit the tire went flat so I thought I'd holed the tire, but when I backed off to make the turn into hot pit the car lurched to a stop. I limped the last 60 feet or so to the paddock, expecting a shredded tire - waiting friend pointed out my wheel wasn't turning. Once parked I could see the caliper pointing up into the wheel and the lower bolt completely free of the carrier. When everything had cooled enough for me to start disassembly I found the thread in the lower gone and the upper bolt hanging on and bent at a 30-degree angle. The caliper-to-wheel contact had compromised the wheel to the point that the flat was caused by the grooves worn into the middle of the wheel. Time for studs methinks...
As ever: when there's any doubt, there is no doubt -- either stop right there and pull off the racing surface or ease back to cool-down pace and pit to get the car throughly examined.
Continuing at speed after hearing anything or feeling anything just risks your life and the lives of those around you, trusting you to make good decisions on track.
