997 GT2/GT3 Forum 2005-2012
failure of rear caliper bolt
Old 07-29-2010, 09:34 AM
  #46
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
we need part numbers
Working on it.
I did all 8 bolts on my last GT3 with the Time Serts parts above (Have extra if you want.) and it seemed to work well. I still think long term, I prefer studs, but I just got them, so I don't know. My shop is Orbit, they do a lot of work on Cup cars, they all have studs, he seemed to prefer studs, so I am going with his recommendation.
Old 07-29-2010, 09:52 AM
  #47
scott40
scott40's Avatar
Originally Posted by Electric Lizard
I'm curious as to why this would not be a warranty item. Does PCNA claim that the caliper or carrier are normal wear items?
Given the safety aspect of this issue, I'm a bit surprised that Porsche isn't stepping up to the plate with at least a recommended fix.
Yes, I too am not able to understand how this would not be a warranty item, especially if the dealer is doing the pad changes.
Also, if this problem is present on all 997s, it should be fairly widespread. Does PCNA know it's a problem?
Old 07-29-2010, 09:57 AM
  #48
Asquared
Asquared's Avatar
I think it is only the GT3s that you have to remove the caliper bolts to change pads. The regular removal of the bolts seems to be the problem, so I think it's only a major issue on the GT3s, and you would only have to change pads frequently if you track it regularly, which they probably what they use to say it's not covered under warranty.
Old 07-29-2010, 10:08 AM
  #49
scott40
scott40's Avatar
So the Turbo and GT2 have a different design?
It's totally ridiculous that Porsche builds and markets a car for the track and street, and won't cover items such as this under warranty.
Old 07-29-2010, 11:21 AM
  #50
Electric Lizard
Pinecone Watchman
Electric Lizard's Avatar
Does anyone actually know what PCNA's official stance is on this issue? This is not a repeat of the M96 engine's IMS or RMS problems due to the safety aspect, the apparent fix cost and the much smaller number of units involved. You would think that the recent Toyota fiasco would have taught manufacturers not to mess with braking issues.
Old 07-29-2010, 11:34 AM
  #51
Carrera GT
Wordsmith
Carrera GT's Avatar
I'm sure Porsche's "official" stance is simply that it doesn't exist and some drivers are driving in a way that causes the failure of an otherwise perfect work of engineering. I believe the marketing tag line from Porsche for 2011 is "Some people don't deserve to drive Porsches."
Old 07-29-2010, 11:49 AM
  #52
obsessedone
obsessedone's Avatar
Did you do all four holes as a preventive measure? Was it doable as a DIY?
Heading to track and didn't have a lot of time so did 2 damaged holes only (still only took about an hour & sure it will be quicker next time). Plan to do other side when I get back from track - they will certainly fail sooner or later. I often change rotors at the track - rather do this in the luxury of my home garage and do it when I have no time pressure even though it is a fairly quick job.
Not an overly challenging DIY, just be careful to make sure the drill and tap are lined up with the original hole, they tend to follow the hole, but you could go crooked if not careful. Since if you screw up replacing the carrier will be around $1k might be good to let your shop do the TImesert if there is any question of having the skills necessary.
Old 08-15-2010, 02:02 PM
  #53
Asquared
Asquared's Avatar
I put two timeserts in LR caliper yesterday. Once I had the right tools, it was very easy (I had to buy a new drill because the one I had was too big to get square inside the wheel well). If I can do it, anyone can.
I bought enough inserts to do all four wheels, but I'm going to do them when I'm already in the there for something else.
Old 08-15-2010, 06:57 PM
  #54
spare tire
spare tire's Avatar
Allen,
Blackhawk on Wednesday. test your brakes.
Old 08-15-2010, 10:45 PM
  #55
Asquared
Asquared's Avatar
Originally Posted by spare tire
Allen,
Unfortunately, I can't on Wednesday, but I only have to wait another week until ABCC with Chin and then TRAC the following weekend where I can repay the beers I owe you.
Old 10-11-2010, 05:46 PM
  #56
rprellwitz
rprellwitz's Avatar
[QUOTE=TRAKCAR;7750878]I just picked up my car with studs, to remove the rear caliper I must now undo one 10mm bolt to have enough room to move the caliper of the studs. I do not have the specs yet, but they are different due to differnt uprights rear than a CUP car.QUOTE]
TRAKCAR - I was wondering if you had any additional information on these studs? Are they a part that can be easily sourced or something that was fabricated by the shop you work with? I would like to deal with this proactively rather than after a failure but being in WI it is a bit impractical for me to take it to the shop that did your work!
Realizing the front caliper only needs to be removed when swapping rotors does this become a concern on the fronts as well for cars that see frequent track use?
Old 10-11-2010, 05:50 PM
  #57
TRAKCAR
TRAKCAR's Avatar
I never got an actual part number and will ask again next week when I bring my car in, but it should be the same thread as the bolt, just longer right?
I did the fronts, but the fronts should be OK for a while.
Old 11-05-2010, 10:43 PM
  #58
mojom3
mojom3's Avatar
Did you ever get any part numbers on the studs? Or length and type of nut?
TIA
Old 01-13-2011, 11:21 PM
  #59
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Update?
Old 01-14-2011, 12:02 AM
  #60
Terry L
Terry L's Avatar
I had a front caliper bolt fail also. So timecert all of them.
Quick Reply: failure of rear caliper bolt
