Door pulls?
sburns32034 (01-02-2024)
I agree with RSman, it would be easier to have them custom made say through TechArt or Gemballa. As for adding weight with custom material in the doors? Very little difference I would imagine.
How much weight does the door pull save over the regular handles? I have to run some calculations to see how many 100,000'ths of a second the weight difference is going to make
Personally, I think the whole RS door panel change look rediculous. They still use the molded door panel like the other models. Just look at the speaker grill. They just remove the door pocket on the bottom and change a lever for a pull and a cover. If you look back at a vintage RS door panels on old 911s, it is a completely different piece. It is a completely flat panel with just a simple handle and fabric pull. These simple changes on the new RS hardly make it look retro.
GT3 player par excellence
i think we should just remove the door completely.
it saves about 60lbs per side if not more.
your windshield will never fog up again.
but you do need to buy a few more warm jackets.
