Look what came today........
Originally Posted by grussell
Watt,
Are you going for that LWFW and clutch?
garrett,
are you going to lower the gear set? it's still too HIgh. I'm 1st, 2nd in the mountains.
and where did you get the Champion RS 98's??? how much are they?? TIA
btw, these basic seats are decent, the best stock seat they have had in years.
Originally Posted by watt
probably. i want to feel it for while and see what's needed.
garrett,
are you going to lower the gear set? it's still too HIgh. I'm 1st, 2nd in the mountains. So far, the gears are ok for my use
You can get them from Arling or Wheel Enhancement
garrett,
9.6lbs!!!!!!
Would you mind measuring the vertical distance from the shell base to the bottom of each of the guide cutouts in the head? (In other words, I want to see if this seat will fit me from the top of the shoulder to the bottom of the ... um ... bottom.)
Originally Posted by Carrera GT
That's ambitious. I've been tempted to order just the shell out of the PET (which is what you have there, I presume) and then retrofit the cushions, brackets and sliders from the 996 inventory. I hope the rest of the bits arrive quickly for you.
I tried the 996 GT3 euro seat rails and sliders, they do not fit.
