Clear Bra
Sam is one of the best in the country. Did an amazing job on the entire front end of my 997S. Seamless!
http://www.premiermobilegroup.com/
That's very nice work. It's also the first time I have heard that the entire front end can be covered. Is that true, or is it my imagination. If I could eliminate that ugly cut line just past the headlight, I might reconsider. Is there any reason why this can't be done?
I appreciate the input, but I have to say that I am really not convinced that this is the way to go. I have had experience with my recently departed 2005 C2 Red Coupe and every nick very painful, but the clear bra look (at least what I have seen so far) is very distracting. The buildup at the edges is maddening. Is there anyway to prevent or minimize that problem?
When my GT2 is clean, the clearbra is really really hard to tell.
Originally Posted by Carrera GT
I just saw a "pro" job on a white GT3 and it was junk. I saw a Carrera GT in Seal, it looked like a respray from across the room. : |
I prefer to tape up for the track and have the paint serve its purpose the rest of the time. A few stone chips aren't the end of the world.
If you are in LA, you are welcome to check out my car, it's hardly noticeable.
GT3 player par excellence
sam is great, and if his work cannot satisfy you, then you should just not use clear bra, b/c it wont get any better than what his shop can do.
on SY, almost any film will be invisible, so is on dark colors as well as silvers.
but on white cars, it WILL be noticeable.
this is not due to install.
but the film is not 100% clear, sam may chime in.
even at 99.9999% clear, you can see a tint of yellow and that b/c obvious on the white paint.
perhaps white cars dont need bra. one of my GT3 didn't have bra on it (white), you dont see the chips until you get very close.
On a white vehicle, it is more maintenance on white than any color due to what we have come to call the "clear coat" effect. From the paint and body work industry, it is known that the more clear coat applied onto a white surface, the more yellow tint that will come about. For those with white vehicles, just take a look at the front / rear bumpers and you'd be able to see that there is an off-white difference between the panels.
With full panels wrapped, this effect is minimized as you may not see where the drastic cutoff is on the center of the hood / fenders. If having protection is important to you, then it is an option to consider for full panel wrap. The film needs more cleaning / waxing than any color due to this effect that is compounded when dirty.
What's most important here as mooty and stuka have kindly mentioned already is that the installation makes a world of a difference in any color. As for maintenance and wax buildup, this is quite easy to do...we always inform our customers to not brush wax over the seam as this would show the outline of the film on the hood and fenders (that is if the customer did not go with the full panel wrap). The wax buildup can be removed with alcohol / microfiber, qtip, etc, but the reason for us to inform the customer on not brushing wax over the line is to save him / her the work of having to go back and wipe up the wax. It is also not necessary to tape up the film edge before you buff because if you are buffing over the edge fo the tape, you will still get wax buildup on the film and on the unpainted surface where the tape ended. Just wax up to 1/4" of the seam and move on. It is not necessary to wax every single inch of the film.
PREMIER PROTECTIVE FILMS
ClearGuard PPF Specialists, Spectra PhotoSync IRD & CeraLuxe IRD, Authorized Modesta and Nanolex Dealer
www.facebook.com/premierprotectivefilms
B: 510-623-1308
sales@premiermobilegroup.com
See Our Projects! http://www.facebook.com/premierprotectivefilms
CLEAR BRA CLEANER -TRACK MARKS ON CLEAR BRA - PF1 TTR!
http://www.premiermobilegroup.com/pf1_products.shtml
B: 510-623-1308
I guess everyone has their opinion on what bothers them most...I simply can't stand stone chips, and as close to invisible as a well-installed film is, the decision is very easy for me. Obviously others disagree.
Gary
Gary
ArmorGlove in Cos Cob CT. They have done my M5, C2, and GT3. Have the C4 in line for the full treament. Joe Kane is the US head of all the franchises and CT is where they do the training.
When you say "full treatment", does that mean what it sounds like, i.e. the full car end to end? The cars I have seen all have the film end about mid hood. What would it cost to do the entire car? What does it look like next to an untouched version?
ps. You can delete your duplicate post by using the "edit" icon (lower, right corner of your post) and then check the "delete" box on the edit window.
