997 GT3 official specs
#61
Originally Posted by NJ-GT
- A variable steering ratio is garbage. Race cars don't use something like that for a reason.
- 19" wheels? what kind of track tires is this car going to use?
Don't fear 19" wheels on the 997. The new car was designed for it. The 19" on the 997 is like the 18" standard on the 996. I'm sure tire makers are busy responding.
- Why is Porsche fitting the car with a 5mm spacer instead of making the rear wheel on the right offset?
- PASM? is this used on the Cup cars?
#62
Mk.1 GT3 had 5mm spacers at all corners as well, factory fitted. Reason was not that they didn't want to make 2 diffeent wheel sizes, since Mk.1 GT3 widths and offsets were unique for the GT3 in comparison to the Carrera.
Any drivers aid in a GT3 is in my opinion.
Ciao,
Ciao,
#63
guys - PASM is not a "drivers aid". It is simply computer controlled rebound and dampening in the shock valving - that it! Just like motons, etc., it is of course compatible with adjustable ride height (yes threaded spring perches) and sway bars. the only diff is you can switch the valving program from the cockpit
if you remember walter rohl was raving about this because on track you can definitely stiffen things up. it takes the stock handling a notch higher without sacrificing street ride. this is a good thing ...
as far as TC goes, its on the CGT for a reason. and yes you can turn it off ... again, no big deal
and yes, for the non drivers aid purists, the car has ABS, just like MK1, 2, and any other street legal car that will ever be built by porsche (even the 996 cups have it). and no, you can't turn it off (taking the fuse out doesn't work properly either)
come on fellas - if you want a track car, buy a cup car. the GT3 is a track day club car, not a real race car no matter what you do to it. always has - always will be
#65
#67
I would have my GT3 without ABS any day, so much for desired drivers aid.
No thanks to TC and PASM as well. Who's doing the driving, you or is the car driving you? Sounds like many here should looking at sport sedans loaded with drivers aid and other useless gizmos, but each to his own.
Ciao,
Ciao,
#68
Originally Posted by MrBonus
I am dearly in love with this car. I am taking donations and tips of any kind as I'm starting a "MrBonus 997 GT3 Fund."
#69
Ciao,
Ciao,
Originally Posted by leif997
I'm in for $0.02
#70
Originally Posted by 997Vancity
that would suck if we couldnt get those seats in NA.
But why not cause there on the carrera GT's right?
#73
- 0-99mph in 8.7 secs can't be compared with a 0-100mph on the 996 GT3. I bet the new car is using a shorter R&P and shorter gears. That alone makes a huge difference.
- I hope it's just a TC with an on/off switch and not a PSM.
- Only 415Hp? not good. This time the 997 TT will be a faster track car. The 997 GT3 is getting more weight and the 997 TT is losing it. The power difference is 62Hp. Expect the U.S 997 GT3 to come at 3160 lbs with an almost empty gas tank.
#74
Originally Posted by MJSpeed
PASM on the GT3 is very different then that on the regular 997's!!
I realize the GT3 is a 'street car', not a dedicated track car, but a track-oriented car should avoid as much extra stuff as possible - that is what makes it fun to drive. I hope Porsche is not caving to the people who complain their GT3's were too harsh for the street.
#75
