997.1 Carrera 4S
Old 02-22-2017, 10:57 AM
Gene K
Gene K's Avatar
Default 997.1 Carrera 4S
I'm looking at buying my first Porsche. Ive found a car that I like very much and am looking for opinions.
Car has 66,000 miles and is on the original clutch and original IMS.
One Owner with all Service Records. Owner was meticulous.
Car looks more like 16,000 miles. Tires are 80+%. Brakes are 50+%.
No Oil Leaks. Passes an Independent Inspection.
Price will likely end up in the $35,000-37,000 Range.
2007 997.1 Carrera 4S
X1 Artic Silver
DC Stone Grey Standard Leather
404 Turbo 19" Wheels
P1S Power Seat Package with Memory
XSC Porsche Crest Headrests
680 Bose Sound
810 Floor Mats Interior Color
267 Automatically Dimming Mirrors
480 Manual Transmission
1. Is this a fair price for the car?
2. Ive been told the IMS issue is a bit overblown for 2007 MY and later. Is this true?
3. I know it depends on how hard the 75 yo owner was on the car but how imminent is the clutch replacement?
4. Ive heard some earlier dual mass clutches can be an issue and expensive to replace. Is this car late enough that it's not a concern?
5. Most importantly is this a car you would consider? If not why?
Gene
Old 02-22-2017, 11:09 AM
semicycler
semicycler's Avatar
997.1 IMS bearing only matters on the early 2005's. Later 997.1's have a larger, non-serviceable, but more reliable bearing. 997.2's do not have an IMS so no IMS bearing. No worries here.
When searching for your dream pcar, first figure out what options are must haves for you. Things like AWD vs RWD, sport vs base, full leather or not, cab vs coupe, color combo, etc. Some options are easy to add afterwards (PSE, sport mode). Others are not (full leather). Then when you find a car with nearly all the matches go for it. Pay for a PPI incuding a DME report. If all looks good complete the sale.
The car you are looking at seems reasonable on the surface. You say it passes an independent inspection - do you have the report? Did it include a DME overrev read out? Paint gauge readings to determine hidden body work/repairs?
Old 02-22-2017, 01:16 PM
Gene K
Gene K's Avatar
1 - 2203 ic / 1898 hr
2 - 396 ic / 1721 hr
3 - 53 ic / 426 hr
4, 5, 6, - 0 / 0
1901 Total Hours
66,337 Miles
Some random misfire codes they say are pretty normal.
Paint checked normal.
It was noted that the tires (Bridgestone S04) do not have Porsche Approval.
Old 02-22-2017, 01:18 PM
Falcondrivr
Falcondrivr's Avatar
Seems very close my current car. Buy it and drive the crap out of it. You'll enjoy every mile.
Old 02-22-2017, 01:21 PM
kellen
kellen's Avatar
Sounds like a good deal. Price is definitely on the low end for that model.
Old 02-22-2017, 01:31 PM
voiceprint1
voiceprint1's Avatar
I will just say, initially I was not crazy about the stone grey interior, but over time I barely notice it, and it hides dirt better somehow better then black which constantly shows dirt and fingerprints (not that my car has any).
Old 02-22-2017, 01:42 PM
Comanche_699
Comanche_699's Avatar
Sounds like a great price, and I similarly wasn't into the stone grey interior in Froggy, but everything about the car has really grown on me, and I couldn't imagine my car any other way.
Hides dirt pretty well - but mines got fingerprints and mud and all else.
Though I'm in a narrow body, bought mine with 54,000 miles, just clicked past 108,000 yesterday.
Old 02-22-2017, 01:46 PM
DC911S
DC911S's Avatar
Seems like a solid buy at that price.
Old 02-22-2017, 02:24 PM
Gene K
Gene K's Avatar
Porsche Approved Tires.... What's the consensus on this?
The Bridgestone Potenza S04 (Almost New) seem like a pretty decent tire. The only Spec difference I can find is the fronts are 91 Load Index and the car originally had 87. Could the stiffer front sidewall cause a chassis balance issue? Could this be offset be adjusting air pressure?
Old 02-22-2017, 02:44 PM
frankyluis23
frankyluis23's Avatar
Porsche tires are like underwear, you're going to be replacing them often. With that said, try them out and if you don't like them replace them when the time comes. The Bridgestone Potenza S-04 is actually a decent tire and much better than the Hankooks and from what I hear much better than the Pirelli P-zero N2.
Old 02-22-2017, 04:23 PM
mickfluff
mickfluff's Avatar
35k would be a great price IMO even 37k would be top notch.... for comparisons sake.
http://www.racperformance.com/2007-P...ton-TX/6071262
Old 02-22-2017, 05:28 PM
captainbaker
captainbaker's Avatar
OP, when looking at a car some things for me are deal killers: wrecks, salvage title, poor overall appearance (translates to poor maintenance).
The DME report is actually quite good and indicates the PO babied it. No paint work, original owner, receipts, great price........why are you waiting? Remember the 4S is a wide body 911 and usually command a premium with all things being equal. This car should be in the $40,000+ range.
Old 02-22-2017, 05:35 PM
rickdogg82
rickdogg82's Avatar
The S04 is commonly recommended in this forum and works great.
Old 02-22-2017, 07:20 PM
Rikky001
Rikky001's Avatar
Looks like a great car. Drive it and see if it is something for you.
Price is good too.
Old 02-23-2017, 09:22 AM
dannysf
dannysf's Avatar
This sounds like a great car. I'm actually half way on a deal on a 2006 C4S with 62K miles. I'm paying $38,000 and it's not 1 owner. Yours is a better deal. Personally I would prefer higher miles with service records before a lower mileage one. This shows that the car has been driven, things have been sorted, and car was cared for. Plus, it's still averaging what would be considered low miles per year. The car is damn near the bottom of the depreciation curve and it's a 4S manual. If you like the car itself, pull the trigger. Can't go wrong at the price you're paying.
Quick Reply: 997.1 Carrera 4S
