Tire Pump
Old 01-19-2017, 01:14 PM
GT2RSobsessed
GT2RSobsessed's Avatar
Default Tire Pump
Before the long Winter sleep in the garage, I was inflating my tires to 50psi with a foot pump. I built up an unnecessary sweat and eventually broke the foot pump from the excessive repetitions to get all 4 corners up to 50.
Before I purchase one for future use from amazon or the rest of the interwebs, I wanted to see what fellow Rennlist members use to pump up their tires. Old school standing bike pump? Electronic portable tire inflator w/ auto PSI adjustment? I've gotten an electronic portable tire inflator/battery jumper combo in the past and it was terrible at inflating anything.
Thanks in advanced.
Old 01-19-2017, 01:22 PM
Hula
Hula's Avatar
I always blew my fuses using a 12-volt compressor so went for the Goodyear i8000 120-Volt Direct Drive Tire Inflator.
Old 01-19-2017, 01:27 PM
GT2RSobsessed
Yes, one of the options I've seen on amazon say "The tire inflator operates on 12 volts DC and MUST be used with a power port that supports 15 amps. Some 120W sockets might be fused with 10 amps fuses (not supported)."
I have no idea how many amps these 12v connections in our 911 support.
Old 01-19-2017, 01:36 PM
anthony42hat
anthony42hat's Avatar
I just use my air compressor. You can buy a small one from Lowes, Home Depot, etc for under $100 that will handle the task and can be used for some other little jobs in the garage as well.
Old 01-19-2017, 02:05 PM
19VFB19
19VFB19's Avatar
+1 small capacity air compressor
Couldn't even begin to imagine hand or foot pumping 4 tires to 50 psi
Air Compressor and a Longacre tire guage makes things very easy
Old 01-19-2017, 02:32 PM
AltVelo
AltVelo's Avatar
Wow, floor pump! You must have worked up a good sweat. Most floor pumps aren't built for volume but PSI so that must have taken quite a while. I use one of those a regular basis on my bicycles(road and Mtb).
Why not a basic AC compressor? The prices are very reasonable for a 1-2 gallon(less than $80). I can't stand the little 12V ones as they seem to all have a very high pitch and not reliable. I assume you meant to keep in the garage.
Old 01-19-2017, 02:39 PM
BIG smoke
BIG smoke's Avatar
Foot pump? Too old school for me.
Battery jumper inflation in the frunk of the car.
Dual tank oil compressor on the garage wall.
Great for kids bikes, and toys. Wife will even check and fill her own tires with the gauge and tire fitting.
AND, I blow out my in-ground sprinklers every year. (saving $1oo/year to have it done)
You need tools.
Old 01-19-2017, 03:47 PM
GT2RSobsessed
Yes I worked up a big sweat, and I mean to keep this product in the garage
You need tools.
Battery jumper/inflation kit I have, but when I tried using it on my daily, it seemed like it was not even inflating or was just taking too long. This compressor will stay in my father's garage where my 911 is. I own a co-op and dare not street park the 911. But when I purchase my own house, I will need plenty of tools.
PS I went with a 3 gallon air compressor and a tire gauge that connects to the compressor for under $100. Thanks again all.
Old 01-19-2017, 06:24 PM
Astur
Astur's Avatar
I realize that in your case this is "after the fact" but I have one each of the following:
http://www.ebay.com/itm/Husky-12-Vol...3D301638823330
http://www.ebay.com/itm/KOBALT-Elect...-/301638823330
They both work with 12VDC AND 120VAC, both show current and accurate tire pressure on hook-up and both shut off automatically once the dialed in pressure is reached. I personally always use it on 120VAC but it's nice to know I can also "travel" with either one.
Old 01-19-2017, 07:10 PM
renncayman
renncayman's Avatar
Electric 12V pump here
Old 01-19-2017, 11:50 PM
8202632's Avatar
I have one of these in each of my cars. Works flawlessly and has saved my rear many times.
http://www.viaircorp.com/70P.html
Old 01-20-2017, 03:12 AM
turbozv
turbozv's Avatar
https://www.lowes.com/pd/Kobalt-120-...tor/1000092575
Old 01-20-2017, 07:46 AM
1990nein
1990nein's Avatar
Old 01-20-2017, 12:39 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,414 Likes on 858 Posts
I used to use one of those battery operated units that I kept plugged in to power in my garage.... it was loud, annoying, and slow to fill. It was fine but I got tired of it.... you can get a decent one at any auto parts store.
I finally did it right with a compressor.... see my thread here:
https://rennlist.com/forums/997-foru...ompressor.html
Peace
Bruce in Philly
Old 01-20-2017, 12:41 PM
8202632's Avatar
i will tell you that the viair one filled my coworkers raptor tire from full flat to proper pressure in less than 5 minutes.
Quick Reply: Tire Pump
