A couple more weeks I guess
Old 11-19-2016, 07:24 AM
user 72902
user 72902's Avatar
Default A couple more weeks I guess
Getting close.
Old 11-19-2016, 09:16 AM
German888
German888's Avatar
Very nice! 4.0?
Old 11-19-2016, 10:34 AM
vern1
vern1's Avatar
Sweet!!!!
This the toughest point as you can almost taste it!!
Have had mine for 2 weeks and have just hit the break in oil change period at 1600kms.
Its sweet
Old 11-19-2016, 11:29 AM
user 72902
user 72902's Avatar
Originally Posted by German888
Very nice! 4.0?
Thanks!
Old 11-19-2016, 11:31 AM
user 72902
user 72902's Avatar
Originally Posted by vern1
Sweet!!!!
Its sweet
We were in the same boat so I'm looking forward to being as pumped as you are!
Thanks!
Old 11-19-2016, 05:19 PM
German888
German888's Avatar
Can you give the full run down on your build?
Old 11-20-2016, 08:09 AM
user 72902
user 72902's Avatar
Thanks!
Old 11-20-2016, 10:26 AM
cvtbenhogan
cvtbenhogan's Avatar
Nice. If you don't mind me asking about the scoring, do you drive in the winter and what was your oil consumption like over a 4K interval? Just another nervous .1er with a dirtier left tail pipe.
Old 11-20-2016, 01:37 PM
user 72902
user 72902's Avatar
Normal driving
Old 11-20-2016, 02:16 PM
one-rennlist
one-rennlist's Avatar
Originally Posted by jkw911
I was not having any issues or symptoms and elected to do a preemptive rebuild. However, once dismantled they found piston and cylinder scoring similar to what Ben Z has documented as well as lifter damage. I added on some additional maintenance items but I'd suggest contacting Flat 6 and they will do a much better job at explaining the scope of work. Thanks!
At what mileage was it rebuilt? And why? Just a bad feeling?
Old 11-20-2016, 04:41 PM
vern1
vern1's Avatar
I had mine rebuilt because of scoring. Winter driven. Noticed it last spring after 1000km road trip to Hershey. Drivers tailpipe was black. Burned about a liter over that trip. No other noticeable symptoms
LN bores out the cylinders (mine went to 4.0L), had upgraded pistons, rods, bearings etc etc, machines the heads. I added cats, headers, gt3 tb and comp plenum
Old 11-21-2016, 05:52 PM
cvtbenhogan
I typically don't let the car sit more than a couple of weeks without driving it so it sees occasional cold temps but not snow. Any time it goes out it runs long enough to get the oil up to temps; I didn't have any measurable oil consumption even on a 1,000 mile road trip. My Blackstone oil analysis were immaculate so I assumed I was doing everything correct. Go figure.
Thanks JKW and Vern.
Old 11-22-2016, 10:32 AM
Spiffyjiff
Spiffyjiff's Avatar
hey JW, shoot me a line after you break it in - we'll turn the rabys loose on some local back roads.
and do you plan to track it? i can help you with that too.
Old 11-22-2016, 12:38 PM
nk215
nk215's Avatar
That's a very ballsy move on your part. I wouldn't have the gut to spend that kind of $$ ($10+K?) to look into something that has zero symptoms.
+ No measurable oil consumption
+ Never sits for long
+ Oil analysis results are perfect
+ No symptoms
2 independent trusted mechanics told me that w/o oil consumption and other symptoms, many cars with scored piston walls outlast their owners ownership. In fact, scratches on piston walls that you can't really feel with your fingers are considered normal on most engines.
What's the current mileage on your 911?
Old 11-22-2016, 01:07 PM
user 72902
user 72902's Avatar
I've been waiting for an up close look at yours!
Quick Reply: A couple more weeks I guess
