997.1 error codes 2187/2189 and high idle
Old 09-17-2016, 11:54 AM
Koenbro
Koenbro's Avatar
Default 997.1 error codes 2187/2189 and high idle
The CEL came on yesterday, on my 2007 C4S with Tip and 58,000 miles, due to codes 2187/2189. After a brief search on the internet, loose oil/gas caps came up as possible causes. So I cleared the codes and tightened the caps, but the CEL came back a few hours later.
I also just noticed last night that, when idling in Park, it revs at ~1,100. In Drive with the break on and the car not moving (no pressure on the gas pedal) the idle revs drop to normal (around 700-800). Also the idle is a little rough. Any ideas what causes this? Thank you all.
Quick Reply: 997.1 error codes 2187/2189 and high idle
