Paint chips from stones...
Aaaaargh! It happens. I've got several now in my hood, on the bumper. How big is too big for simple touch-up paint? Short of repainting the whole front end, is there a medium fix?
(Don't you HATE gravel trucks?!)
I read here on the forum that the best way to fix small ones is by a toothpick or even a needle. After clening and drying the spot they just used a tooth pick or needle and dipped it in the paint and then put it in the hole. If you use the paint brush that follows with the touch up paints they are usually much too big and you just create a big puddle of paint that overfill the hole in the clear coat.
I haven't tried it but seems logic and a good way of fixing the small ones. Maybe up to 2 mm in diameter.
Rocky Mountain High
I've used Dr. Color chip in the past. It works well and it helps you avoid the big paint blob that you often get with touch up paint.
2009 C2S 100K miles
I use Porsche touch up paint, lacquer thinner, and a toothpick. As others have said, the toothpick is really nice.
I take a little fold of aluminum foil, drip in some paint (just a drop or two), drip in a bit of lacquer thinner, mix a bit with your toothpick, then with a new toothpick, dab the thinned paint into the chip.
Doing it this way will take a few "coats" to fill the chip. If you don't use lacquer thinner, I would still try a toothpick as you can put on smaller amounts than the brush.
If you use a brush or over-blob it, then wait a few days for it to fully harden, and use a clay bar with lots of lubricant to sand down the bump.
I tried Langka.... rip off stuff ... it would just pull the paint right out of the hole.. or disolve it.. not sure what it was doing but it never worked for me.
Today, after 16 years of owning two Porsches and 300K miles total on them, I just ignore most of the chips and then one day, just get on my knees and do a bunch with the brush and no laquer. I don't worry about bumps or under filling any more... so over that perfection thing especially now that I have 100K miles on the car.
Peace
Bruce in Philly
Peace
Bruce in Philly
Received 5,388 Likes
Dr. Color Chip. Practice on the wife's/GF/Housekeeper's car. Then do the Porsche.
