997.1S-Should fans keep running after car turned off?
On a few hot days I have gone into my garage 15-30 minutes after turning the car off and the fans were running. Turning the ignition on then off without starting the car turned the fans off. Is this normal?
I've noticed it, so I believe it is. It's odd, the fans come on even when the car is off and been off for 15/20 min.
If the fans turn on, leave them ON. Engine temp sensors turn them on. Re the engine lid cooling fan... let it run and only when it stops you may raise the lid but not before the fan stops, or if you install an external fan extraction air out from the bottom of the engine like this:
Sir Thomas Lord of All Mets Fans
Originally Posted by toona
Mine does it almost daily here in central Texas...
Edit - just back from another unnecessarily long (but oh so satisfying!) errand and it's in the bat cave and the fan's a-whirring. 100 F here.
There is only 1 small fan on the engine lid. There are 2 fans (1 on each side) in the front and they are known to go bad... On a very hot engine the front fans will stay on.
When you pull into the garage and before you shut engine off, cycle A/C off and then back on you can hear the front fans - pretty loud.
