997.2 Oil leak getting inside my LF wheel????
Old 05-23-2016, 07:38 AM
storch
storch's Avatar
Default 997.2 Oil leak getting inside my LF wheel????
Strut or oil cooler maybe??
Car had front damage in the past and I recently had lowering springs installed.
Nasty mess
Old 05-23-2016, 08:47 AM
user 72902
user 72902's Avatar
Nasty mess
Do you have an external oil cooler? A picture would help to see how much oil but my first thought was PS fluid. Strut is also a good suggestion.
Old 05-23-2016, 09:39 AM
semicycler
semicycler's Avatar
You need to jack up the car, remove the wheel, and visually inspect for the source of the leak. If it's the strut it should be obvious.
Old 05-23-2016, 10:10 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,410 Likes on 855 Posts
Check your power steering fluid... you may have a leak in your rack.
Shocks usually don't leak that much fluid. Just take a white paper towel and wipe where the silver piston enters the tube. If leaking, you will have black gunk... the fluid mixed with dirt.
Keep us posted.
Peace
Bruce in Philly
Old 05-23-2016, 08:09 PM
storch
storch's Avatar
It looks to be originating from the under body panel and jack pad location.
Right at the rear of the LF wheel
It must hit the inside of the wheel slightly.
Oil looks clean where it drips straight to the floor.
I'm guessing it's the steering?
Can it be re sealed or am I in for an expensive part????
Old 05-23-2016, 08:40 PM
nwGTS
nwGTS's Avatar
Pray it's not your steering rack. They are non serviceable and are ~$1800
Old 05-23-2016, 08:50 PM
Bruce In Philly
You don't have to pull the pan.... just check your reservoir in your engine compartment.
Someone just replaced their rack ... did a DIY and purchased a rebuilt unit.... posted here on Rennlist.
Peace
Bruce in Philly
Old 05-23-2016, 11:22 PM
storch
storch's Avatar
I only 8000 miles on the car.
Is the power steering fluid tank black and right next to the oil fill???
997.2S
I don't read German labels well.lol
Feels like clean vegetable oil on the garage floor, a little nasty when mixed with break dust.
Not feeling the new rack option at $1800
Old 05-23-2016, 11:37 PM
997_rich
997_rich's Avatar
My bet is brake line fluid. Check your brake reservoir. Installer probably had the the caliper get away from him and hang by the hose at some point (it happens to the best of us).
Old 06-01-2016, 12:32 PM
storch
storch's Avatar
Ok
I finally took it in and the service shop says it's the front strut/ shock???
I don't have a price yet for parts or labor just that it's not going to be cheap!
It only has 7500 miles on it but the same shop just installed lowering springs and did the alignment 500 miles ago.
Could the strut have been damaged while changing springs????
Old 06-01-2016, 06:01 PM
mdrums
mdrums's Avatar
lowering springs are the death to PASM shocks....wrong way to lower a 997.
Either instal stock shocks and the new LF OEM shock...or lower the car the proper way with Bilstein Damptronic B16 coilovers....these allow you to still use the 2 PASM shock settings.
You can't short cut Porsche engineering....lowering springs are not the proper way.
Quick Reply: 997.2 Oil leak getting inside my LF wheel????
