Bleeding while replacing brake lines
I am replacing the factory brake lines with Goodridge brake lines. Can I bleed one wheel at a time while I replace one brake line at a time? I use a Motive bleeder. My thought is to change the right rear brake line and then bleed it. Then repeat the process for the remaining three wheels. I would release the pressure between each brake line replacement.
I see no reason that won't work. There's always the risk of a bubble traveling way up the line, but the brake lines usually have a high point trap that prevents that.
My guess is the work needed to lift each wheel up again after the brake line replace,net. This can be fixed with a 2 post lift or those scissors lifts that push on the 4 corner jack points
