minimum rotor thickness on 997.2 C2
Anybody has the specs of the new and minimum rotor thickness for a 2010 C2 with stock brakes? (I know you can see it on the rotor hat but I would rather not remove the wheel only to check that...)
Thanks!
Thanks!
You can see the wear bars on rotor without removing the wheels. Look at the holes that vent air/heat. There are a few of them that are completely filled in...once your rotor erases those its time to swap out.
Believe me, I am super OCD I even bought an expensive micrometer to measure the thickness. It's much easier just to look for the wear bars and eye-ball it.
Newbies Hospitality Director
https://rennlist.com/forums/997-foru...ighlight=rotor
Check out the pic I posted in post #2 in this thread. It shows the wear dimples on Porsche 997.2 rotors. There are a some other pics a the rotors a few posts later.
