Best bluetooth/aux solution for 05 997 Cabriolet
#31
I placed my mic in the instrument cluster cowl:
Upside is it's virtually hidden in shadow (the photo shows it much more because I had the flash on), and completely shielded from wind (would be especially helpful in a cab, but even in a coupe with open windows). Downside is it picks up the turn signal clicking louder than if the mic was on the A-pillar.
I chose not to mount my phone. The available mounts either place the phone where it blocks the airflow from the center vent, and I need all the A/C I can get here in the tropics; or they place the phone sticking out into the passenger footwell where 100% my wife would eventually kick it and snap the mount off. Plus I have mine in an Otter Box Defender case so the clip mounts don't fit so well.
I have a USB adapter in the center console lighter socket and keep a charging cord in there. There's enough gap to let the cord run through without pinching it. I leave the phone on the passenger seat when I'm alone; if I have a passenger then I set the phone horizontally on an angle in front of the shifter boot leaning against the cubby below the HCAV control. With the rubber-coated Otter Box case it has never slipped off.
I use this. Love it because it clips on (GPS, ...) and rotates
Amazon.com: Kenu Airframe | Portable Smartphone Car Mount (Non Phablets) | Black: Cell Phones & Accessories
Where are you based?
#33
In streaming mode you need to have the radio set to the Tranzit's input frequency (I have it programmed into button 5, which has a depressed center and little tactile nub I can find by touch without taking my eyes off the road). Calls automatically come in and mute the music stream. Streaming is also used for GPS from the phone app. If the Tranzit is in streaming mode and you aren't streaming anything, it will be relatively silent (I can hear a little hiss now and then). If you go to any other frequency you will hear a lot of static/garbage. So if you want to listen to regular radio stations, you need to long-press the control button to switch modes.
In radio mode, you can use whatever preset you want to listen to music. If a call comes in, it will mute the radio and the caller ID will show on the PCM screen. BUT: to answer the call you will need to get on the Tranzit's frequency AND press the control button to answer. Hence why having that frequency programmed into the #5 button is convenient.
I never listen to commercial radio anymore, so mine is always in streaming mode. Except when I leave the car for service, then I switch it to radio mode so the mechanics won't mess it up trying to get the radio to play.
I always have my phone in BT, but if I put the key in the ignition in without my phone on me, since I leave the Tranzit in streaming mode and the PCM set to the Tranzit's frequency which around here has at least 2 transmitters stepping on it, I am assaulted by loud noise. Which serves to remind me I forgot my phone!
#34
How did you run the wires for the Mic?
I can't use anything that clips into the dash vent. I'm in the southern end of FL.
#35
The Tranzit has 2 modes, streaming and radio. Toggle between them with a 5-second press of the control button (you'll hear an audio indication).
I've been using the streaming mode as you describe. Once the unit is paired to my phone, and with the music paused on my phone if I go to the pre-selected frequency (I used https://www.siriusxm.com/frequency to find a free one) I start to get get a hiss at 70-80% volume. This same hiss you can hear on lower volume songs. I'm guessing that because I have a cabriolet, I turn the music up more. There is no "interference" from other stations, just a hiss.
Is this normal or do I need to wrap my antenna connections in aluminum foil?
I don't really listen to the radio either, but even in streaming mode, I'm able to scan and find other stations... Is this normal too?
Thanks again!
#37
Thanks for the detailed response.
Thanks again!
Thanks again!
I have an iPhone 5 (not S) running the last version of ios 7, and the hands-free volume all the way up.
You might try calling the 1-800 help hotline listed in the iSimple manual. I called them about something during the install and they were quite helpful.
#38
Hey Racetwin2 I'm getting one installed and haven't seen the switch yet. You mounted yours down by your leg. How did it mount?
Any other guys do it different?
Thanks a lot! This has been a GREAT thread!!!
#39
i get a little distortion but I think it is due to the iDevice's volume being too high. I need to experiment. I have the Bose system. I don't have any soft intro to songs.
#40
I use the default frequency even though there are stations that step on it if the phone isn't on (there are no truly free ones around me, what with all the pirate transmitters off-shore). In streaming mode with Spotify paused and the volume way up, I can occasionally hear a very slight hiss that increases in volume slightly for a few seconds followed by a soft pop, then it goes silent again and repeats. That's as close as I've ever come to experiencing to what youyou are describing. I have the unit itself wrapped in a thin closed-cell foam packing sheet, just to keep it from rattling against anything, but no foil on the antenna wires.
Only issue, is that I hear the popping sound that you described when I am on calls... :/
#41
Only issue, is that I hear the popping sound that you described when I am on calls... :/ Are your calls crystal clear?
#42
You see in my video earlier in the thread where I placed it. It's ideal to me since its close to the right hand and you can also hide the thin cable behind the panel that you anyhow need to remove in order to get the PCM out.
#43
Hi guys
I hope everybody is still here. I had it installed, and it doesn't automatically connect to the Bluetooth on my phone. The dealer tells me I have to push the button for 6 seconds to get them to link up. Is that true? Did they set up the dipswitches wrong?
I want it to connect as soon as I power on. Pushing the button has by itself been intermittent. Seems like I hear a teeny relay behind the dash when it does link up.
Any advice is gratefully appreciated.
#44
It should connect automatically. Mine does. I never have to do anything when I get in the car. Both with my previous Samsung S5 and my current Iphone6
You should not normally not touch the dip switches as I understood. Mine worked directly from the packaging. I didn't even have to use the app in the phone to set it up as I remember.
#45
