Engine Hatch Emergency Release
So.... It appears that the emergency release cable for the engine hatch is located behind the left rear tail light assembly. Its not clear to me how one would get to it if needed, as you need the engine hatch open to get to the screws to remove the tail light assembly. Perhaps my emergency release cable is not routed correctly?
2007 911S
2007 911S
On my 2009, it is under the left/driver side tail light and is taped down to the chassis with a fat piece of black electrical / fabric tape. To access it, slide a hooked, thin wire between the bumper and the light fixture..... it will hook and pull. The surfaces are pretty smooth IIRC so the only thing you will hook is the tape and or cable.
Peace
Bruce in Philly
Peace
Bruce in Philly
Bruce is correct. Just to make sure it was where I thought it will be, it's easy enough to pull off the driver side tail light and see where the cable is sitting in case I ever need to get to it and to make sure it is where it is supposed to be (I think I've seen a post with someone saying that their cable got moved during car work and not put back correctly). When removing the two light screws, I recommend placing a cloth over the gap between the bumper and the engine compartment so you don't drop them down there accidentally... I almost did.
I gotta drawer full of extra screws and door snaps.... just in case stupid strikes.
Peace
Bruce in Philly
