Fabspeed Tip Adjustability
I can't tell if you have a 997.1 or .2. On the .2, you can loosen the collar that hold the side muffler to the center muffler and get some lateral adjustment by slipping the side pipe connection in or out a little bit. I forget if a similar slip collar exists on the 997.1.
You can also get some fine adjustment just by loosening the tips just enough to move the tips a little and yawing them a little to one side or the other, but you don't want to do any big adjustment that way. It's worth removing the tips and making sure the muffler outlet pipe is in the same position on both sides first.
