Lamin-X kit from Suncoast
I installed the Lamin-X (6%) kit from Suncoast (headlights, fog lights, and side markers). The lightest tint you can buy, so more of a subtle change. I saw something similar on the 991 GTS and thought it looked good so gave it a shot. Good for making 997.2 DRL's a little less obnoxious too, they were so damn bright.
In case anyone was considering doing it here are pics of how it turned out. The third pic is with the DRL's on.
Thanks. Yeah, I know and I actually like to keep the DRL's on, but seeing how bright they are compared to other brands I actually think they might annoy other drivers. Maybe not, but anyway this lessens the brightness by 6%. Kit was only $60, so I'll try it for a while.
Apparently the 991 GTS comes standard with tinted headlights:
And... I suspect that tinted headlights from the factory are an optical filter designed to provide a perceived lens color but will not reduce the light output. If they do it's definitely a dumb poseur option.
Not sure if GTS comes standard with this or if it is a factory option. The conversion kit is pretty pricey at Suncoast ($2,700). I think you're right it probably does not affect light transmission, at least not materially.
http://www.suncoastparts.com/product...EXTERIORLIGHTS
Yes they should be bright enough to see, but if too bright they can be distracting other drivers which is exactly the opposite of safety's sake.... Just my opinion, you can have yours. The point of such forums is to share, not condescend BTW.
Note: I am currently attempting to matte black paint my 997 lights' inner housing and will plan it out before I attempt and post.
Just some clarification. The 991 GTS headlights are NOT tinted. The inner housing is matte black instead of chrome or light gray as in the 997. That's what makes them seem darker. And also realize that tinting headlights them is illegal in most states.
There is no kit that I've found for the 997.2. That kit you shared I've seen before and is actually for the 991.
