Polished exhaust tips
Removed my exhaust tips and went at them with citrus cleaner and 0000 steel wool, they came out great! Finished them off with Never Dull.
Before and after picture attached!
Dan
Dan
Rocky Mountain High
Strong work.
Received 5,388 Likes
Nice work.
Sent from my iPhone using Rennlist
I bailed and am having the tips media blasted and ceramic coated in silver.
I recently bought a set of tips that had been spray painted, and in researching ways to remove the paint, a common notion I found was to avoid using steel wool--it leaves tiny steel particles embedded in the surface, which then rust. For whatever that's worth...
Post a picture of your ceramic coated tips when you get them, I would be interested to see how they come out!
Having built some furniture, I know rusting steel wool particles can cause a problem in light colored wood. But wood is a fairly porous material that will capture the fragmented particles. I've never had this problem on steel. After polishing, clean fully.
