Touch Up Paint for Curb Rash on OEM Wheel
Old 11-22-2014, 05:57 PM
gripshifter
gripshifter's Avatar
Default Touch Up Paint for Curb Rash on OEM Wheel
Got some curb rash while parallel parking today, almost brought a tear to my eye. It's only a minor spot, but it's 2 deep nicks.
I was planning to sand it, apply some Bondo, and cover it with some touch-up paint, since the surface area is not large. Does anyone know the touch up paint color for stock OEM Carrera Classic 19" wheels? I definitely do not wish to refinish and repaint the entire wheel.
Thanks in advance!
Old 11-22-2014, 06:33 PM
awrryan
awrryan's Avatar
I was told Wurth silver. I have some but never tried it so can't say if it's true.
helispud
helispud's Avatar
Here's a kit http://www.autogeek.net/german-wheel...epair-kit.html. You propbably only need the primer, paint and clearcoat.
I have used the Wurth. It's a match to the original silver.
Old 11-22-2014, 06:36 PM
awrryan
awrryan's Avatar
Good to know. Thanks.
Old 11-22-2014, 07:07 PM
Marine Blue
Marine Blue's Avatar
I think the Wurth will only match if you spray it on. I tried spraying it into a container and applied with a brush and the color didn't match at all.
Old 11-22-2014, 09:26 PM
Tcc1999
Tcc1999's Avatar
Kudos! Good catch (and very good point)!!! AFAIK, Wurth only comes as a spray and is probably formulated to dry in a certain way when atomized. Applying it any other way may, well, muck up the works. I don't have any experience using the product but I've read from a number of sources that Wurth is the standard match for silver wheel repair. Lots of videos floating around that show you how to do the repair ranging from **** retentive remove wheel and then tire off the wheel, to a quick and dirty covering of the wheel with tape and paper. Now that I think about it, in the videos that I've seen, everyone sprays and seems to feather the paint.
Best of luck on your repair.
Old 11-24-2014, 06:29 PM
Edgy01
Poseur
Edgy01's Avatar
You can try ColorScratch.com for a can. I think the wheels are a GT Silver formulation. Someone else step in. I've forgotten more than I recall now.
Old 11-25-2014, 10:16 AM
Falcondrivr
Falcondrivr's Avatar
Use the wurth silber and the wurth clear coat. Leave the tire on the rim. Use playing cards to stick in the crack between the tire and rim, and then blue tape to mask.
It will work perfectly.
Old 11-25-2014, 10:35 AM
BIG smoke
BIG smoke's Avatar
My used winter lobster were pre-curbed. Thus I had no tears in my lap. Though I do feel your pain.
Do keep an eye out for a classic wheel set. Sometimes they come up as singles or broken sets. A repair/paint will cost you 100-200 bucks depending on where you get it done.
Old 11-26-2014, 01:49 PM
sullivas
sullivas's Avatar
I called Dr. Colorchip, the owner has a Porsche as well. He made up some Porsche silver wheel touchup that matched perfectly. I didn't do the typical Colorchip routine with it, just cleaned the scrape and applied the color with an artist brush. Although DIY, you have to look to find the damage now.
Quick Reply: Touch Up Paint for Curb Rash on OEM Wheel
