"Headlight beam adjustment fault"
Old 07-27-2014, 07:35 PM
PasPar2
PasPar2's Avatar
Default "Headlight beam adjustment fault"
09 997.2S 25k miles.
Got this msg yesterday, now its there everytime I start the car. I dont have dual xenon headlights so I assume I dont have auto leveling headlights. I have never seen my lights dip since buying the car last yr.
car has CPO but before I face the pain of going to the dealer, I want to try and trouble shoot it a bit.
an pointers?
Old 07-27-2014, 10:45 PM
sidwin
sidwin's Avatar
it's cpo... i would call and make the appt. probably headlight ecu is out.
Old 07-28-2014, 11:53 AM
JuanK20
JuanK20's Avatar
I don't mean to hijack your thread but i also have the same message on my car. It happened right after i lowered the car. However, the auto adjustment still works so i dont think the sensor(s) is bad. The lights still adjust themselves when i start the car and seem level. Not sure if there is a way to reset?
OP. You have CPO, i would just go to the dealer and save yourself the headache. As for me, i have to try and toubleshoot myself.
Old 07-28-2014, 05:04 PM
PasPar2
PasPar2's Avatar
Made and appt for wed. Will update the thread when more info becomes avail. As of now, the service advisor confirm its strange for this error to come up on a non dual xenon car.
Juan, do you have dual xenon?
Old 07-28-2014, 05:19 PM
Minok
Minok's Avatar
997.2 not in the US? All US cars came with bi-xenons, and the related leveling system.
Not sure if the halogens were just the conventional old-type mechanical adjusters by hand.
Old 07-28-2014, 06:57 PM
PasPar2
PasPar2's Avatar
It is a US car. I think have xenons but not "dual xenons"...
mine look like these
http://www.kistudios.com/images/head...im-samples.jpg
not like these
http://www.2040cars.com/_content/car...727269/004.jpg
Old 07-28-2014, 07:57 PM
JuanK20
JuanK20's Avatar
Mine is single xenon as well.
Old 07-28-2014, 08:47 PM
Petza914
Petza914's Avatar
Received 6,134 Likes on 3,907 Posts
You can force the headlights to run an auto-level cycle. With the key off, turn the headlight switch all the way on, then cycle the key to the auxiliary position (the one before the car starts that lights up all the warning lights). The headlights will drop down and then lift up and auto-level. My 997.1 lights only do this when I run the test, not each time I turn them on.
Schwabenblitz987 (03-11-2020)
Old 07-28-2014, 09:25 PM
PhilD
PhilD's Avatar
FWIW I have a 997.1 with single xenons and my headlights auto adjust every time I turn them on.
Old 07-28-2014, 10:46 PM
PasPar2
PasPar2's Avatar
Just tried it and they did dip and came back up. all seemed well but the error still comes up. I never saw them dip in a year of ownership... strange.
doba_s (10-03-2019)
Old 07-29-2014, 04:33 PM
Minok
Minok's Avatar
not like these
I'm making an educated guess here...
I think all xenon headlights have the auto-leveling mechanism. Because of the intense and precisely controlled beam pattern of these light types, the fog lights were no longer needed, and the beam system has a leveling system that makes sure the light is properly aimed (that the mechanical cutoff system is working right) whenever the headlights are turned on.
The dual beam sample, is the 'adaptive' headlight system, I believe, which turns left and right. I've got that system on my car and the dual-lamp look is what I have.
Old 07-29-2014, 05:00 PM
GSIRM3
GSIRM3's Avatar
You are correct. The "adaptive" lights you refer to are PDLS, or Porsche Dynamic Light System. Got to love all the Porsche acronyms.
Old 07-29-2014, 07:05 PM
Ptech1
Ptech1's Avatar
Possible one of the plastic brackets for one of the sensors (one front, one rear) was broken while lowering the car. Lights would still self adjust on start up, but error would appear due to lack of travel from sensor. Just an educated guess...
Old 07-29-2014, 07:36 PM
PasPar2
PasPar2's Avatar
Ptech, are those visible without lifting the car or taking the wheels off? if so where do I look?
Old 07-29-2014, 08:21 PM
PasPar2
PasPar2's Avatar
I now see the issue.. I see some bracket hanging down by the rear drivers side wheel... I am pretty sure thats it. Wonder is CPO will cover this. We shall find out tomorrow.
Thanks Ptech!!
Quick Reply: "Headlight beam adjustment fault"
