Exhaust tip cleaning method
Old 07-24-2014, 01:13 AM
niner niner seven
niner niner seven's Avatar
Default Exhaust tip cleaning method
Cleaned my exhaust tips this past evening, thought I'd post about the method and products used. Thanks to Edgy for posting re. nevr-dull in a previous post. I used a microfiber and water in-between cleanings along the way. First started with the citrus then pad finally polish. All products for under $10 (I lovvvve $10 DIY projects).
Tips had not been cleaned in 90k miles, going to start cleaning more often.
Before:
Post:
Old 07-24-2014, 01:38 AM
Robocop305
Robocop305's Avatar
Just like brand new. Thanks for the tip!
Old 07-24-2014, 07:36 AM
RobC4sX51
RobC4sX51's Avatar
Looks great! I did mine last spring and still enjoy the appearance change at the back of the car. New tips from Suncoast are over $700, SharkWerks has some nice ones for $500! But 20 minutes and $10 is so much better and the satisfaction of DIY
Old 07-24-2014, 10:24 AM
tigerspill
tigerspill's Avatar
Are they easily removed for cleaning? Or did you do them on the car?
Old 07-24-2014, 11:24 AM
niner niner seven
Thank you for replies.
Left them on car. Worked each one for about 10 to 15 mins.
Old 07-24-2014, 11:56 AM
WindyCityC2S
WindyCityC2S's Avatar
I use barkeepers friend and a sponge. One step works, 2 minutes, looks awesome.
Old 07-24-2014, 12:09 PM
danit
danit's Avatar
Yep, Bar Keepers Friend or the French version Bon Ami work great.
Old 07-24-2014, 01:52 PM
tigerspill
tigerspill's Avatar
Thanks.
One more question - when using the steel wool - did you always rub on one direction (front to back) or random directions?
Old 07-24-2014, 03:01 PM
niner niner seven
Thanks.
back and forth, up and down, every which way
the wool pad is the key in this process mixed with the citrus solution
Old 07-24-2014, 04:38 PM
ksozay
ksozay's Avatar
Wow! Will be adding this to the list this weekend.
Thanks for the tip!
Old 07-24-2014, 06:42 PM
tigerspill
tigerspill's Avatar
Those look good. I just got a tin of the Nevr Dull!
Old 07-24-2014, 09:01 PM
mray2686
mray2686's Avatar
Great job - looks great! i'll give this a shot this weekend!
Old 07-24-2014, 10:15 PM
Marc in AK
Marc in AK's Avatar
Everyone enjoys a good tip polishing...
Old 07-24-2014, 11:47 PM
Chaos
Chaos's Avatar
Me too
Old 07-25-2014, 12:42 AM
Lvt19672
Lvt19672's Avatar
Those tips are the ****!!! Nice job.
Quick Reply: Exhaust tip cleaning method
