REAL cost for PDK clutch job?
Old 10-02-2013, 11:54 AM
Tacet-Conundrum
Tacet-Conundrum's Avatar
Default REAL cost for PDK clutch job?
In a different non related thread I asked this question and someone mentioned, as a guess, maybe $3000 for the clutch job.
I personally am thinking it could be twice that much just due to the complexity. Im thinking in computer terms that the.PDK will be an FRU Field Replaceable Unit and could cost at least twice more than $3000.
By the time the PDKs start wearing down and out there should be a service in place. Talking second hand non-Porsche units to save money.
Old 10-02-2013, 01:40 PM
alexb76
alexb76's Avatar
PDK cannot be serviced, at least not by Porsche or any shop we've heard... so, basically when it goes you must replace. How much that costs? I have no idea, 100% it'd be over 5K, I'd guess closer to 10K.
Old 10-02-2013, 02:05 PM
Ptech1
Ptech1's Avatar
You would be correct in assuming over $10k for unit alone, easily. And that's reman prices from Porsche. NEW warranty replacements are north of $20k. For a transmission.
Old 10-02-2013, 02:13 PM
mdrums
mdrums's Avatar
There are no clutch parts or packs that Porsche sells to do a clutch job on PDK. However PDK shifts so perfectly it really does not wear out clutches. Even the guys that race PDK have noticed the clutches are not worn so they just replace the 2 fluids and keep on driving.
Old 10-02-2013, 02:37 PM
kosmo
kosmo's Avatar
i hope so. The clutch job on Italian makes (f1) are very pricey.
Old 10-02-2013, 04:27 PM
PJorgen
PJorgen's Avatar
I had my PDK replaced under warranty. Service adviser told me it's a $17-20k job.
Old 10-02-2013, 05:44 PM
Robocop305
Robocop305's Avatar
Once in a while I smell clutch when on sport mode. Is this normal? Yes, clutch replacement on f1 transmissions are around $5k.
Old 10-02-2013, 07:36 PM
alexb76
alexb76's Avatar
Why did you have to replace? If it shifts so perfectly as stated above then why it failed?
Old 10-02-2013, 07:41 PM
Alan C.
Alan C.'s Avatar
I had mine replaced at 2000 mi. due to a small leak.
Old 10-02-2013, 08:59 PM
mousecrab
mousecrab's Avatar
Better stay with good old manual.
Old 10-02-2013, 09:31 PM
Hatzenbach
Hatzenbach's Avatar
How about when using "launch mode"?
Old 10-02-2013, 09:33 PM
fbfisher
fbfisher's Avatar
Only if you want to be assured of replacing the manual clutch. I'm guessing the delta between manual clutch replacements and PDK trans replacements is quite large.
Old 10-02-2013, 09:58 PM
kosmo
kosmo's Avatar
A friend had hers replaced after going into limp mode at the track. I believe it overheated. Warranty.
Separately I saw my tech replace a PDK on a Turbo S w/ less than 600miles. Yikes.
He said they dont touch these trannys.
Old 10-02-2013, 11:46 PM
Bijan
Bijan's Avatar
It is a wet clutch system, assume Porsche do not expect it to wear out anytime soon, other than random failures.
Old 10-03-2013, 12:36 AM
slicky rick
slicky rick's Avatar
Heard that wet clutches are a lot more durable than the regular dry clutch type. Im surely hoping if the pdk unit you have has gone through the first couple of thousand miles without problems it will go through its life without a hitch. Te usual problems happen early in the life of the pdk. Have a unit where the pdk was replaced due to a noise around 2k km on a 4s. Warranty of course. The replacement also developed a leak and was again replaced after 1k km. after that problem free already.
Quick Reply: REAL cost for PDK clutch job?
