Porsche 996 & 997 JL Audio Stealthbox Style Subwoofer Upgrade
Old 07-18-2013, 06:45 PM
DELREYCUSTOMS
Former Vendor
DELREYCUSTOMS's Avatar
Default Porsche 996 & 997 JL Audio Stealthbox Style Subwoofer Upgrade
Ever need more BASS in your Porsche but your partner is 6'2''? We have the solution with our 8 inch footwell box. This is a full size JL Audio 8W3V3-4. No shallow mounts here. For full sound and amazing front bass. Perfect for convertibles, carrera and GT cars. Also easily removal to reduce weight for those long days at the track. Stealthbox design proper speck air space. preloaded with the woofer and a 1 year JL Audio Warranty.
Price $699.99
Fits all Porsches and chassis and motor sizes Including GT2/GT3
Porsche 996 1999-2004
Porsche 996 Turbo 1999-2005
Porsche 997 2005-2012
Porsche 997 Turbo 2006-2013
Boxster 99-2012
Cayman 2005-2012
987 Cayman/Boxster 2005-2012
Available in a Black, Dark Grey, Light Silver Carpet
8W3v3-4
W3v3 8-inch Subwoofer Driver (250 W, 4 Ω)
If you need an 8-inch subwoofer that can create outstanding bass in extremely small enclosures, the 8W3v3 will do the job and surprise you with its power and accuracy. It employs the same technologies as its larger diameter brethren to deliver a whopping 0.375 in. (10 mm) of controlled, one-way, linear excursion.
The 8W3v3-4 is best used with amplifier power in the 75W - 250W range and is optimized to operate in a tiny 0.30 cu. ft. (8.5 l) sealed enclosure, or a 0.35 cu. ft. (9.9 l) ported enclosure. Detailed enclosure recommendations can be found in the "Specifications" tab.
For more info call 310-827-8121
To order Email SaturnDRCMedia@gmail.com
http://www.ae-33.com
http://www.facebook.com/AEMarina33
http://www.twitter.com/delreycustoms
http://www.yelp.com/biz/al-and-eds-a...marina-del-rey
Powered by DRC Media LLC & Al & Eds Autosound
Old 07-24-2013, 02:17 AM
BLKonBLKC4S
BLKonBLKC4S's Avatar
I can understand in a convertible, but in a coupe??? Besides, 3 x 8's move more air
Old 07-24-2013, 10:33 AM
07C4S
07C4S's Avatar
"gives you plenty of room for your feet still...."
I'm going to have to disagree. I am 6'2" and the remaining space and required foot position looks miserable. Re-engineering the crappy Bose subwoofer looks like a better idea and that location is marginally useful space anyway.
Old 07-25-2013, 04:18 PM
DELREYCUSTOMS
Former Vendor
do you ride in the passanger seat often?
Old 07-25-2013, 04:19 PM
DELREYCUSTOMS
Former Vendor
Attachment 746511
Attachment 746512
i can also do 2 10inch JL w3 in hard top and make it look stock
even do a 13 TW5 and 2 Dyn 11
Old 07-25-2013, 04:24 PM
alexb76
alexb76's Avatar
+1, there was absolutely no room for your feet in that video, I think placement must be re-visited.
Why not an upgrade to Bose crap Sub? and using the same placement?
PS. I think the problem for aftermarket stuff for our cars is the fact that most aftermarket components are massive, for whatever reason. I looked into doing something to my car and there was not a way one could add more bass, better speakers, and amp without taking valuable space in this tiny car. I really think if someone comes up with a solution for the back seat, to replace all the Bose Crap, place all equipment within that slot, plus two 8" subs, is the way to go. Key is finding the components that can fit. Until then, I will stick to my crappy audio as I value room in the car.
Old 07-25-2013, 09:40 PM
DELREYCUSTOMS
Former Vendor
the factory sub is a 4x6 kinda of hard got a 996 in the shop and lets see what i can create
Old 07-25-2013, 11:07 PM
SecretAsianMan
SecretAsianMan's Avatar
DRC you guys have done some good stuff, but that footwell looks pretty crowded to me. I think a drop-in replacement for the bose sub would be pretty popular and I bet you have the skills to pull it off.
Make it an upholstered fibreglass box that doesn't weigh too much and that will sell..
Old 07-26-2013, 12:03 PM
07C4S
07C4S's Avatar
A) On occasion .
B) I care about my passengers comfort as well. Having ridden and driven a number of cars with the offset pedals and crappy footwell space I wouldn't subject my passengers to that for something as vain as a bit more bass. Especially when there are surely better options in the factory location.
Old 07-26-2013, 06:38 PM
gasongasoff
gasongasoff's Avatar
The reason is: physics.
Bass requires compression of air. So you need speaker cones with large surface areas and high excursion capabilities. This combination requires a large box/enclosure in order to generate low frequencies with low distortion and reasonable sound volume. There are ways to compensate for some of these requirements, but you'll never get loud, high quality bass with a single small driver in a small box. It's just not possible.
Old 07-26-2013, 08:16 PM
DELREYCUSTOMS
Former Vendor
hers the box in black work on a oem mod right now
Just another day at the shop the sub boxes are starting to move for the convertibles.
JL 8W3V3-4 rock in the drop tops!
Old 07-27-2013, 04:41 PM
DELREYCUSTOMS
Former Vendor
so we have modified the stock enclosure for a pioneer 8 inch Shallow Sub TS-SW841D. Worked the best.
I tried the Rockford Shallow, Alpine Shallow and the Kenwood Shallow 8 inch subs and the Pioneer sound the best and has no slap on the transmission hump.
We modified the stock housing and it took about 5 hours to manipulate the stock enclosure and rebuild it to work. we left the factory port and it is a big upgrade over the old 4x6. we powered it up with about 350 watts rms of the back end of an alpine PDX-V9 rated at 500 watts but real power out put metered was 348 watts giving me the recommend power of 350 rms. I would recommend using a 500 watt amp still unless you using a higher end amp company that does 350 rms at 4 ohm
ill upload the photos after lunch
Old 08-01-2013, 08:58 AM
Flamingoboo
3rd Gear
Flamingoboo's Avatar
Have you looked at the possibility of squeezing a JL 6W3v3-4 into the stock enclosure? seems to be around the right volume of 4 litres, or do you not think that the drive unit would produce enough output?
Old 08-01-2013, 02:36 PM
DELREYCUSTOMS
Former Vendor
woofer is too deep
we just successfully did the pioneer shallow 8 inch and its a beast
i have photo by the end of the day
Old 08-02-2013, 10:18 AM
Flamingoboo
3rd Gear
I know its a little deep but thought it might work well, excited to see your pictures and results of the pioneer as well as a comaprison to your 8" JL enclosure. Really good work! Respect!
Quick Reply: Porsche 996 & 997 JL Audio Stealthbox Style Subwoofer Upgrade
