What did you do to your 997 today?
#5161
Changed manual transmission lube. Used the Mobile 1 PTX. Marked improvement in shifting and the ubiquitous first gear issue. I don't know what all the stink is about the smell. (Yes, pun intended.) Smells no better or worse than any other lube, in my nose's opinion.
#5162
Painted my brakes.. pretty time consuming task with removing everything and baking the paint.
I have no brakes now too . I thought I could just refill afterwards but the peddle just goes to the floor and wont hold pressure. I guess a full brake bleed is in order.
#5163
#5165
If you run into trouble open up another thread in the 997 forum and we can help you from there.
Beth02CarreraC2 (11-25-2019)
#5167
When you refilled the reservoir, was the bottom out or was there still some fluid left in it up the sides a bit? I don't know the capacity of the reservoir but it might be in the specs somewhere. Try a normal bleed to start and if the pedal isn't good when you're done, you'll have your answer. I believe if you're doing the Durametric activations, the sequence may be different - you follow the sequence in the software when doing that.
#5168
I agree, makes it much more aggressive looking
#5169
Great look and ride height! You should consider adding the 991 sport lip to complete it!
#5171
captain...
personal preference here, but the oem all red tails would look killer on your car,either way she's a beauty...
#5172
KKSwow, I like a lot of tail lights, the problem is choosing.
Wiring day turned out to be a big let down. My buddy at the Dealership hooked up the computer to tell the car it has a fixed wing. Then, I plugged in the third brake light wire from the old retractable spoiler into the TT brake light. No dash warnings, no buying harnesses and no splicing.
Edit....the Check raised brake light message is back and neither 3rd brake lights work........the plot thickens. Guess I might have to buy the wiring harness after all.
#5175
