pagid pads and brake sensors
Old 04-18-2011, 03:44 PM
madporsche
madporsche's Avatar
Default pagid pads and brake sensors
I replaced my stock brake pads with pagid yellow pads and removed all brake sensors as well since there were no holes to put the sensors in. As I expected, brake sensor warning light was on.
Is there any way that I can use pagid yellow pads without both brake sensors and warning light?
And I was also wondering if it is okay to run front pagid yellow pads with rear stock pads. I might want to replace rear pagid pads with stock pads.
Old 04-18-2011, 04:28 PM
Spiffyjiff
Spiffyjiff's Avatar
you "removed" the sensors as in unplugged them? if so, that's your problem - the light triggers when you break the circuit (i.e. or when a brake bad is so thin, the heat burns thru the sensor). reconnect and simply tie back out of the way with some zip ties.
EDIT: altho now that i think about it...i'm not sure if that will clear the error or if you now need to visit the dealer to reset the code.
i wouldnt run pagid yellow front + stock rear. i would talk to a reputable race shop or brake supplier who knows your model and ask what flavor pagids to run in the rear when running yellow up front.
Old 04-18-2011, 05:49 PM
TAI2
TAI2's Avatar
+1 on the sensors. You could make a jumper or put the sensors back and just tie-wrap them back.
For DE I run with yellows all around. I would not run with yellows up front and stock in the rear. I would think that braking would be funky when cold (fronts don't brake well while rears bite) and then when hot (fronts would grab nicely and rears would fade).
Old 04-18-2011, 05:54 PM
Viperbob1
Viperbob1's Avatar
Yes if you reconnect and as said you tie back sensors you will be fine... Light will go off.
Old 04-18-2011, 08:40 PM
tcouture
tcouture's Avatar
I run pagid's and have just zip tied the sensors out of the way. No warning.
RS29 (yellow) front and RS14 (black) rear.
Expect some squealing,
T.
Old 04-19-2011, 12:24 AM
madporsche
madporsche's Avatar
I appreciate all the comments guys
I will do it so over the weekend and let you guys how it goes.
Old 04-19-2011, 01:19 AM
mdrums
mdrums's Avatar
I got some used up sensors from my dealer and cut the wires at about an inch and soldered them together and shrink wraped them and pluged in the plug. Nice and clean and no tied up wires on my shocks. This has lasted me through 3 cars and 4 years. Since I swap out stock pads and street pads all the time.
Old 04-19-2011, 05:33 PM
madporsche
madporsche's Avatar
So basically I can choose either cut off the rest of wires or tie them up, right?
And do I have to do so for all the four sensors? Or I can simply do that for the front ones?
By the way, I appreciate your help.
Old 04-19-2011, 09:19 PM
mdrums
mdrums's Avatar
You wil have cut plug in all of them. all you are doing it completing the loop in the circuit.
Old 05-23-2011, 11:12 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Yellows / OEM swaps seem to work really well with no reported issues doing this -
Old 05-24-2011, 12:35 AM
RonCT
Moderator
RonCT's Avatar
Don't cut them, just fold them up and tie them off. If 997.1, go with Yellow 29s up front and Black 14s in the back (better bias) and 997.2 go with Yellow 29s all around.
Old 05-24-2011, 09:10 AM
utkinpol
utkinpol's Avatar
i did cut them off and shortened ends, then tied them up. much easier this way as chance for me ever to run car with wasted brake pads without knowing it is 0.
Quick Reply: pagid pads and brake sensors
