Red Exclamation Point on Dash Lights ....
The red ! just indicates that there's something important to check on. It could be any of dozens of things ranging in importance from an engine problems (serious) to the fact that you've turned off stability control (trivial).
I'd expect the text display to offer some hint in most cases, or an additional annunciator to be illuminated (like the tire pressure warning light, for example).
.org
Originally Posted by Owner's Manual
The central warning light ! on the instrument panel
lights up if there are warning messages in the
INFO menu.
The messages can be called in the on-board
computer INFO menu: Please see the chapter “INFO WARNING MESSAGES”
INFO menu.
But if you aren't sure and can't check this stuff out yourself, you probably want to get it to a service center.
And check on-line for a PDF Owner's Manual - very handy.
