Seat heaters/Homelink not working
Old 12-13-2008, 05:25 PM
stevewilm
stevewilm's Avatar
Default Seat heaters/Homelink not working
I just fot my 2006 C4S Cab back from sevice at the dealer where they replaced the battery under warrenty. When I drove the car I noticed the seat heater and the homelink didn't work (no indicator lights). I checked the fuse box and there is not a fuse specified for either so I checked them all and couldn't find a bad fuse. Any ideas before i call the dealer next week?
Old 12-13-2008, 06:30 PM
Edgy01
Poseur
Edgy01's Avatar
when you state that you checked the fuses I assume that means you pulled each one out and then reseated it. The schematics seem to suggest C6 for the garage door opener and E1 (left) and E2 (right) for the seats.
Old 12-13-2008, 06:44 PM
stevewilm
stevewilm's Avatar
Thanks. C6 looks good and the seat controls work. ??
Old 12-13-2008, 07:54 PM
Edgy01
Poseur
Edgy01's Avatar
Try resetting the PCM console. The seat heaters are wired through the seat circuit but are switched through the console. Can't suggest anything other than what you've tried.
Old 12-13-2008, 09:55 PM
larrytrk
larrytrk's Avatar
Take it back to them, they need to do the "Handover reset", which they should have done when they replaced the battery!!!!
Old 12-16-2008, 12:02 AM
porschespeeddemon
porschespeeddemon's Avatar
This gets done when it comes off of the truck (think "handing over" to dealer) however, it will not always activate everything on the first try. Homelink/Seat heaters are 2 signs it needs to be done again. Fault memories should all be cleared after a battery replacement.
Old 12-16-2008, 10:17 AM
leneuromancer
leneuromancer's Avatar
just had this same issue and, as indicated, the dealer performed the "handover" procedure and all is now fine
Old 12-16-2008, 05:07 PM
John52
John52's Avatar
Does this happen everytime you disconnect or remove the battery?
Just wondering as this winter is the first time I have stored my 2008 997S.
Will I have to plan a trip to the dealer for a "reset" after I put the battery back in?
Old 12-16-2008, 05:46 PM
gota911
Newbies Hospitality Director
gota911's Avatar
DOn't take the battery out. Buy a trickle charger and you should be good to go in spring.
Old 12-17-2008, 01:02 PM
John52
John52's Avatar
I would use a trickle charger if I could, but car is in a storage bay that does not have an electrical outlet. So to repeat my question, do you lose Homelink/seat heaters everytime a battery is removed or is it just some cars/conditions that it happens with?
Old 12-17-2008, 02:19 PM
larrytrk
larrytrk's Avatar
I would tend to say yes, however, I can't say for certain. You might try a 9volt battery cigarette lighter plug to keep the circuits energized, but I don't know how long the battery would last.
Old 12-17-2008, 05:25 PM
Minok
Minok's Avatar
It seems very odd, that the car is designed to not be able to remember things. Maybe its a safety feature to keep the seat heating from causing a problem by coming on after storage... but given its a button, could it just default to off as it does? Having features 'turn off' with the removal of a battery seems stupid in the days of flash memory.
Old 08-08-2010, 11:21 AM
cr2000
cr2000's Avatar
I realize this is an old thread, but found it after my 2006 C2S just had a similar problem. Periodically the seat heaters will fail to work and the auto-dimming mirrors as well. Turning the car off and back on usually resolves it, so clearly it's not a fuse issue. It'd be hard to show the dealer since it's not a hard failure, rather one that happens intermittently. Anyone else had the same problem recently?
Old 11-21-2010, 04:01 PM
drfous
drfous's Avatar
Received 1,877 Likes on 1,085 Posts
Changed the battery on my car and now the seat heaters and homelink don't work.
Anyone know if the durametric tool will replicate the dealer "handover" procedure to fix this issue?
TIA!
Old 11-21-2010, 04:15 PM
ADias
ADias's Avatar
How many times has been stated in this forum that while batteries are changed in a DIY manner, a battery maintainer should be connected to keep alive the electronics?
Comment posted to warn future DIY battery changers.
Quick Reply: Seat heaters/Homelink not working
