Front end vibration
Front end vibration
new to me 2003 stock suspension, super sport tires with 50% tread left - had wheels rebalanced but still have a fair amount of vibration on the steering wheel and I can feel in in the seat as well. It it varies with speed and pavement quality. On smooth asphalt it is not noticible but on groved concrete it's pretty bad but goes away over 90 mph
any suggestion on what to look for that could cause this?
thanks in advance
thanks in advance
may I suggest you get new tires all around.
had the same experience with my 996TT. Visually the tire treads appeared fine, even measured
~5/32 tread depth.
Put new tires on........problem disappeared !
Tony
~5/32 tread depth.
Tony
i think you said it best when you said: "On smooth asphalt it is not noticeable"
Make sure the tires are properly road force balanced. My car is very susceptible to poor balance, so I have to make sure whoever is balancing gets the tires to under 15Lbs on the road force balancing machine. I had to go through 3 shops until I found somebody who did it right. Sigh...
thanks in advance
thanks in advance
Do the tread surfaces show any signs of scrubbing/cupping or other abnormal wear signs? If so an alignment could be called for.
I run the tires on my 996 Turbo (and Boxster too) right down to the wear bars without real issues other than the tires get noisy as heck and the rears are more inclined to pick something up and get flat.
Note as new tires wear they can go out of balance. This is unfortunately "normal" for big old wide tires as the tread wears down heavy or heavier areas wear away and the tire's balance changes. More than once when I replace the rear tires on either of my cars -- after around 20K miles of service -- the fronts need rebalancing to address the out of balance condition that has developed as the front tires have worn down some.
Might add that often the rear tires develop a bit of vibration too as they wear down but this doesn't seem to be as much a problem maybe because the weight over the rear tires. However, my day to day usage seldom has the car at a speed that makes the rear tire imbalance a real problem. But if I am venturing out on a long road trip where the car will spend hours a day at high speed I generally do this on fresh and balanced tires.
What are your tire sizes? You get to far out of spec and they will cause front diff lockup and shutter.
A sure fire way to test this is if you drive in the rain and its worse then in the dry.
Update
I replaced all 4 of the tires and it is much improved but not perfect - I will take it to get road forced balanced and 4 wheel alignment.
I would now say that the vibration is very minor but I don't want any at all.
Over all the car handles really, really good and the suspension feels great.
Update
Controlsguy21 (12-28-2022)
